68 Fastback
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 30th March 2016 - 12:23am
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 30th March 2016 - 1:20pm
Image All in and sealed upImage
Then onto front inner wheel well, cut away to reveal front of heater Chanel, which thankfully was solid
Stretched/shrunk return lip
Knee bent panel in place
Last edited by Tight yorkie mick on 30th March 2016 - 1:59pm, edited 1 time in total.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 30th March 2016 - 1:44pm
Welded in and ground back
Prep and fit outer sill
Bits and bobs to weld back in, heater to sill edge, in wrong order but you get the idea
Wheel arch put back Image
Leaving me here, bit wobbly due to previous gas welded repairs, a bit of filler and then it's ready for paintImage
Re: 68 Fastback
Post by Editor » 31st March 2016 - 12:41pm
Very envious of your stretcher/shrinker - really does a good job, with a little help from yourself! ;-) ;-)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st April 2016 - 11:38pm
Editor wrote:Very envious of your stretcher/shrinker - really does a good job, with a little help from yourself! ;-) ;-)
Thank you Mr editor.... :) ,
I recon they are a top investment ,especially on these type 3's due to cost/rarity of repair panels , I paid £125 from frost. At the time, floor pan corners were about 50 notes a corner. My car wanted all four. I have to say its been one of the most satisfying tool purchase I've ever made, and I've now used it on many more repair sections, some of which I would have taken hours to make normally and would have looked rough once done. Wish I'd invented them
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 23rd July 2016 - 11:48pm
In paint ImageImage
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 24th July 2016 - 12:06am
Then on to bumper mounts, looks a bit nasty Image
Cut out an old repair and got hanger repair section on Image
So after much faffin I ended up with thisImage
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 24th July 2016 - 10:09am
I'd decided for some reason to leave as much original steel in place, would have been easier to cut the lot out, but wanted a guide for the shape
Repair to air box Image
Finally on and gundged up with sealer, wing fits nice to the repair so all good, soon to be hidden for another 30 years
And a bit under arch, all looked good under here till I poked it with the grinder
Happy to have this side finished
markymarc
Re: 68 Fastback
Post by markymarc » 25th July 2016 - 8:40am
I am glad my squareback didn't need all that welding..........I am better with fibreglass.....well done though.
Mark.
Re: 68 Fastback
Post by broady_6 » 23rd December 2016 - 5:43pm
more I cry, more!
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th January 2017 - 6:36am
broady_6 wrote:more I cry, more!
I hear ya
Ok so passenger side next
Same thing but not as bad except the flap
New bumper mount
Flap area repair section
Then the flap itself
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th January 2017 - 7:06am
Having to post on my iPhone so forgive the multiple posts, the phone gets fed up after a few pictures then dumps the lot, very frustrating
Bumper mount in not as bad this side
Also treat myself to a better welder, then had to retrain on how to use one that works correctly
All done and coated in slightly gone off Salem sealer
It was a good feeling to be done at this end, I can now understand what people mean when they say these cars are more complex than bugs.
Next time It's the front clip.
A perfect rust free example from a dry state. Both looking forward to getting it fitted and dreading it at the same time, got to get this bit right
Chino
Re: 68 Fastback
Post by Chino » 10th January 2017 - 9:12am
Nice find on the clip, I'm sure you'll get it bang on. Look forward to following the progress :)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th January 2017 - 8:27pm
Thanks chino ,It's on already ,I'm playing catch up, now I've mastered Iphone posts,was nerve racking though, took a fair few trial fits before I cracked the welder up
No going back now
Trial fit to make sure there's plenty of meat for trimming
Nail biting trial fit /cut a bit try again
Getting close
I've left the inner strengthening spars to allow lots of overlap to make the repair to be close to original strength
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th January 2017 - 8:36pm
Still found some Rot that I'll sort once clip is on
What hides under here?
Spars starting to lineup
And it's on
And I can breathe out again now
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th January 2017 - 8:51pm
Only a few pictures but around a weeks worth of faffing about ,
Now onto the previous inner wing repair
Oh dear
So I started here
Finally in paint
Re: 68 Fastback
Post by kaddy » 12th January 2017 - 9:13am
Nice work.
Re: 68 Fastback
Post by broady_6 » 27th February 2017 - 9:42pm
Looks like a photo from the production line :D
Re: 68 Fastback
Post by Editor » 28th February 2017 - 1:09am
Just in case folk out there don't realise, the pressed flutes on the inner wing are symmetrical, and I've repaired the usual inner wing rot on one side with a scrap section from the opposite side of a scrapper. The upper edge is more curved, but that can be re-shaped or trimmed as necessary. The spring mount needs removing if the section is from a '71-on car, rather than earlier, but it's nice to make use of a section which is invariably solid in a scrapper to repair the inner wing invisibly.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 22nd May 2017 - 10:01pm
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 22nd May 2017 - 10:07pm
I did look at that and mine was repaired badly for the whole length, for some reason I decided to go with a flat piece , with a view of possibly replacing it if I ever find a suitable cut, I think I was just wanting it done, suppose it will haunt me forever :)
Next up was the brakes and as the car came with a set of Fuch copies I bought Porsche pattern disks
Last edited by Tight yorkie mick on 22nd May 2017 - 10:45pm, edited 1 time in total.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 22nd May 2017 - 10:44pm
Also fitting new bug type calipers as the original ones need plenty of love and one has cracked,
I also looked at Talbot horizon calipers but they are more rare than type 3 ones. I may look at aftermarket ones once I've tried the bug ones. Does anyone have experience of running a type 3 on bug brakes?
Whilst trying to bleed the brakes I found I also needed a rear wheel cylinder Image
Turns out the same part as front 1302 ? Never knew they came with drums on the front , suppose it makes them easier to get hold of, which can't be a bad thing.
Had mixed results using one of these easy bleed kits Image
Until I found that all four flexi hoses had collapsed and didn't pass fluid! Being stood unused for thirty years didn't agree with them.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 22nd May 2017 - 11:05pm
My next project on the list was to fit up some kind of heater, looking at options it was clear that an eberspacher from a bug would do the trick... so I bought one for a bus! Great :) apparently they will cook the occupants in a few minutes, but it was cheap and mostly complete and they did use them in trekkers. How hard could it be?....
Quite hard as it turns out.
Trekker parts are yes super rare/expensive so some fab work was required here's a few pics
Decided to go across the car trekker style as it made most stuff line up and as I'm no expert on these things copying something that is known to work seemed a good idea
So after weeks of rooting through people's scrap piles I found a 150mm diameter 90deg bend that would take the hot air in to the cabin Image
Then take a deep breath a chop a massive hole in the bulkhead!!!
Image Hope this works
Definitely a case of measure twice!
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 22nd May 2017 - 11:08pm
View from inside Image
Re: 68 Fastback
Post by Editor » 23rd May 2017 - 12:43am
Probably essential oop North!
The Type 3 Eberspacher was usually fitted along the side of the front luggage compartment rather than at the back, but maybe that was normally on 71-on where there's a bulge for the airbox. i've not seen enough to register a trend.
