68 Fastback
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 1:32pm
Am I doing something wrong with the picture links Dave?
Re: 68 Fastback
Post by 937carrera » 1st October 2015 - 6:59pm
Try this - the code is complete except for the first "[" and I have linked the picture for you as an example
Copy the URL from the "Direct" link, not the HTML
img]http://i199.photobucket.com/albums/aa21 ... qfpuj5.jpg[/img]
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 7:41pm
Re: 68 Fastback
Post by 937carrera » 1st October 2015 - 7:47pm
Looks like you got it....... now you can get the others working :)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 7:48pm
Last edited by Tight yorkie mick on 2nd October 2015 - 1:44pm, edited 3 times in total.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 7:50pm
That's strange I'm not doing anything different just pulling photo bucket link and pasting it here?
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 8:15pm
If I put just 1 image on its own it works, but if it's more than one or with a write up, it just shows the link no pictures, I've just tried to modify the first post and one worked and the second one just says image. I'm lost :)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 8:28pm
It's says [img width=450
height=600] at beginning on all pics? On both the ones that work and those that don't? I can't see a difference in the code set on either.
Re: 68 Fastback
Post by 937carrera » 1st October 2015 - 9:25pm
You don't need the image size information, thats web html code. All you need to do is go to Photobucket, copy the Direct link details, click on the Img option in the posting box which will give you the opening / closing php tags, then paste the picture link details between the tags.
If it just says Image, that means that the link details are not valid, it can't find a picture to show
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 10:06pm
nearly done this part, bit of zinc weld through paint on to protect it. Image
Appears to be working :) thanks everyone
Last edited by Tight yorkie mick on 3rd October 2015 - 6:25am, edited 2 times in total.
Re: 68 Fastback
Post by purplepeter » 1st October 2015 - 10:12pm
Hold on You two... I'll sort it out! gimme 5 mins!
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 10:15pm
Thanks for trying to help David , I've cut and pasted the post onto my local vw site it shows all pics? On here it sometimes works ,sometimes not, on photobucket I get 4 options I click on the one that says forums etc and it says link copied I then post on here, and get various results
Re: 68 Fastback
Post by purplepeter » 1st October 2015 - 10:31pm
photos are Now showing properly Mick..
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 1st October 2015 - 10:46pm
Thank you Peter , was I doing something wrong? Not the sharpest on this inter web thingy :)
Re: 68 Fastback
Post by Editor » 3rd October 2015 - 1:47am
Sorry the picture posting is being so much trouble.
"http://i199.photobucket.com/albums/aa21 ... 0rrye7.jpg" worked with the previous lot - note it starts http://i199... rather than http://s199...., which simply generates a little image logo.
If you can find the URL in this format, it should only be a matter of copying it to the post, highlighting it and click on Img box at the top of the post, which inserts the [img]and[/img] each end of the image URL.
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 3rd October 2015 - 6:21am
Thanks Dave, I'm away for a few weeks , so I'll give it another go once I'm home. I wonder if it's because I'm posting on an iPhone rather than a full computer? Take care all see you soon
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 19th October 2015 - 12:11am
Back home now , see if I can get some work done, and pics to work :)
Decided to fit the corner part edge to edge rather than leave a seam, taken ages but should look good on finished
Some small infil bits to finish, then grind up and zinc paint, the swage line needs dollying, correct the shape, but I'm happy so far.
Chino
Re: 68 Fastback
Post by Chino » 19th October 2015 - 9:57am
Some great fabrication, keep up the good work :)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th November 2015 - 10:33pm
Thanks chino,
Things have progressed a little
Corner is now finished
I cut a piece of inner arch away for access
Also some under edge of heater channel
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 10th November 2015 - 10:44pm
Then moved onto sill, now mostly welded in
Still have some gaps to fill
Also got some similar ...ish gold paint in satin that should blend in once I rub it back a bit to age it.... See how that goes .
If I fail I'll have to look at a respray, I'd like to keep the faded stuff
Arch bit back in
And a splodge of test paint. Ok it's over some black but not too bad of a match
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 18th November 2015 - 2:22pm
Almost complete this side now, hopefully get it painted this week
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 18th November 2015 - 10:25pm
Finished this side now and in paint :)
Not a bad colour match... Well happy :)
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 29th March 2016 - 2:30pm
Been a while since I last posted, some progress has been made,
Tried panels back on
All good on to next bit
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 29th March 2016 - 11:44pm
The other side
Or the worst side, but having already done it once should be a bit easier Image
I did make a few decisions, first I wasn't going to edge to edge this side as took forever and didn't look that nice once done plus you can't see it anyway!!!
Use my new strinker as much as possible
Having already done one side the making up of the bits went fairly quickly
Tight yorkie mick
Re: 68 Fastback
Post by Tight yorkie mick » 30th March 2016 - 12:20am
