1971 Fastback KBY 217K winter 2016 tidy up
muddy
Re: 1971 Fastback KBY 217K winter 2016 tidy up
Post by muddy » 30th May 2018 - 5:48pm
Before I full fitted the rear seat in I needed to secure my 2nd battery somehow.
I was looking at all sorts of options like universal battery trays, straps etc. But they all needed to be secured to the floor plan. I did not want to drill into the floor pan.
And just like that one Saturday morning I thought of an idea of bracing the top of the battery against the body and cross member that the seat sits on. The bracket effectively jams up to the body/floorpan and will bolt to the cross member.
So out came the cutting disc and welder and I fabb'd up a bracket.
Works a treat and secures the battery quite well.
ImageIMG_4445 by Craig Mudd, on Flickr
Painted up:
ImageIMG_4446 by Craig Mudd, on Flickr
and fitted:
ImageIMG_4447 by Craig Mudd, on Flickr
Instagram: @type3.fastback
muddy
Post by muddy » 30th May 2018 - 5:49pm
Once battery was secure I fitted the back seat.
ImageIMG_4500 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th May 2018 - 5:52pm
Here's some pics of the car as it is.
No idea when it'll be back on the road. Depending on the success of the 3rd master cylinder I may have to resort to fitting the original drum brakes to the rear of the car. :crybaby: :crybaby:
ImageIMG_4438 by Craig Mudd, on Flickr
ImageIMG_4440 by Craig Mudd, on Flickr
ImageIMG_4442 by Craig Mudd, on Flickr
ImageIMG_4444 by Craig Mudd, on Flickr
Post by broady_6 » 30th May 2018 - 10:03pm
that's looks very tidy! drum brakes aren't bad at all, they just need more regular maintenance. I also love the seats, have you got a link for the dye? I think i need some!
Post by kaddy » 31st May 2018 - 6:54am
He mentions Autobrite Direct for the seat dye.
I must get some my self, the seats look brilliant, as does the rest of the car.
muddy
Post by muddy » 31st May 2018 - 6:19pm
@broady
Yeh, dye is from autobrite: https://www.autobritedirect.co.uk/index ... stain.html
Not sure what the dye transfer will be on my clothes. But I let it dry for a few days and then gave it a wipe with some interior cleaner and not much came off onto the cloth. I'll give it one more clean and I think it will be fine.
I'll be gutted if I have to remove the discs and put the drums on, but needs must if I want this bad boy on the road.
muddy
Post by muddy » 31st May 2018 - 6:21pm
Oh and thanks to Broady and Simon Kelly I got my seat runners today, so will probably get passenger seat whacked in this weekend.
Do I need to grease the runners and if so what bits? the metal or the plastic or both? Do I need to grease the seat bits too?
Post by broady_6 » 31st May 2018 - 10:02pm
No grease required, nylon is self lubricating. and if you great them they will only attract dirt and start to bind up and wear. Given that I expect you will adjust it to get comfy and never touch it again. it'll be reet :D
muddy
Post by muddy » 16th June 2018 - 10:27am
So this last week or so, I've been fitting the rear part of the carpet, seat runners and passenger front seat.
ImageIMG_4514 by Craig Mudd, on Flickr
ImageIMG_4515 by Craig Mudd, on Flickr
ImageIMG_4519 by Craig Mudd, on Flickr
ImageIMG_4517 by Craig Mudd, on Flickr
Can't really fit the front portion of the carpet until I've resolve my brake issue. :(
muddy
Post by muddy » 16th June 2018 - 10:43am
I've also fitted the Porsche master cylinder (pictures to follow) and whilst I've not been messing about with the brakes, I temporarily fitted the fuel tank and ran the engine up each evening. Started each time on the button, does need the timing adjusting so it's perfect.
Whilst doing this, I thought I'd best check the fuel sender even though it worked fine when I dismantled the car (and I'm glad I did). The fuel sender had been removed from the tank, during the resto whilst I cleaned the tank and painted it, so had not been in contact with any fuel for 12 months.
I removed the sender, and moved the float to identify a full tank, switched ignition on and it only read 1/2 tank, as well as the needle bouncing all over the place. Not good.
I first checked the resistance between the spade connector and metal chassis of the sender and the resistance didn't seem normal, I couldn't get a good reading, it jumper from 200 ohms to 2k ohms????
So I stripped the fuel sender down and measured the resistance across the resistor wire, I was reading approx 90 ohms full and 10 ohms empty, and although I didn't have the specs I guessed this was pretty accurate based on other things I've seen in the past. (thermistors etc are normally 100 ohms, so it's a normal standard value).
So I checked the resistance between the wire and the spade connector and this was good approx 0.5 ohms, however the other wire to sender chassis was pretty much none existent (2k ohms). I cleaned up any oxidisation, but I could not get the resistance down.
So I improvised and soldered a wire on the brass base plate to a ring crimp. The idea being that when it's bolted to the tank the earth will pass through the tank fixing bolt. I'll also add a new earth wire to chassis, as I don't want to be removing paint on the tank to make a good earth with the tank mounting brackets.
Once the wire was in place I checked resistances and it was pretty perfect from spade to sender chassis.
Connected to the car, and got a full tank with no needle movement, also checked other positions and the fuel gauge read perfectly. :D :D
Built sender back up, now ready to put back into fuel tank. But gonna give the fuel tank another coat of paint as it's been marked having been fitted and removed (a hundred times).
ImageIMG_4537 by Craig Mudd, on Flickr
ImageIMG_4538 by Craig Mudd, on Flickr
muddy
Post by muddy » 16th June 2018 - 10:46am
On Thursday I tackled the seat belts.
I think they are original but not sure.
I stripped them down and put them in the washing machine.
They came out great, look almost new :D
Just need to paint the brackets up silver and I'll get them fitted.
ImageIMG_4536 by Craig Mudd, on Flickr
muddy
Post by muddy » 16th June 2018 - 10:50am
One question I have is, one of the seat belt brackets is different to the others, it's quick release ??? it attached to a ring bolt.
This is it:
ImageIMG_4533 by Craig Mudd, on Flickr
This is a normal bracket:
ImageIMG_4524 by Craig Mudd, on Flickr
Is the quick release bracket standard??
I'd like to to change it to a normal bracket, does any one have an old seat belt that I could have a bracket from?
Post by broady_6 » 16th June 2018 - 12:09pm
This is it:
That looks much more like its from a race harness rather than original type 3.
Post by 937carrera » 16th June 2018 - 5:06pm
Yep, looks like Willans to me, the use of a ring bolt supports the theory. It's not that they are quick release, it's just the standard way of utilising existing seat belt mounting points in combination with the ring bolts. The spring clip it to prevent them coming off.
muddy
Post by muddy » 16th June 2018 - 6:26pm
I can only assume that it's replaced a standard bracket that was rusty?? And that was all a previous owner could find.
Any ideas where I could get a standard bracket from? Danny doesn't have any.
Post by broady_6 » 16th June 2018 - 8:05pm
it looks easy enough to make, unless your die hard on original. which i assume you aren't be cause of the 944 brakes. Chain drill the slot then file it out, big hammer in a vice to get the bend. you're more than capable. Its provably easier than finding one
Post by 937carrera » 16th June 2018 - 11:09pm
Try a wanted ad on here, you never know
muddy
Post by muddy » 17th June 2018 - 4:43pm
[/quote]
In this instance I'd like it to be original. I've had to compromise with the 944 master cylinder to get my brakes working. I'll buy second hand set when the time comes, at the moment I'll live with the quick release bracket.
muddy
Done :thumbsup: :thumbsup: :thumbsup:
muddy
Post by muddy » 17th June 2018 - 4:45pm
Just to update this thread with the brake progress, I've sourced and fitted a Porsche 944 master cylinder. Re-made all new front brake lines.
Bled the brakes and now waiting in anticipation for it to be all ok. So far so good. :D :D :D :D
ImageIMG_4544 by Craig Mudd, on Flickr
Post by broady_6 » 19th June 2018 - 7:56am
Dont know if it didnt submit, but theirs no wanted add gone up for the seat belt bit, just the pushrod.
Aaronslimvw
Post by Aaronslimvw » 11th August 2018 - 12:41pm
Awesome work mate!! I’m having similar issues with the car not going low enough too.. going to get some lower shock re-locators and modify them so they are 2-3” lower to get the beam on the floor. What are you doing as far as steering goes? Flipped track rods? Quick steer?
jake@facewest.co.uk
Post by jake@facewest.co.uk » 26th December 2018 - 11:32pm
Don't know if you've seen this but found this on Youtube:
https://www.youtube.com/watch?v=TcZjfq6hLAs
Post by broady_6 » 22nd January 2019 - 9:16pm
How are you getting on? we haven't heard from you for a long time
Post by Editor » 28th January 2019 - 12:09am
The Fuel sender overhaul is dealt with at http://home.clara.net/hallvw/fuelsend.htm . Another member had the same problem and fixed id somewhat similarly.
