The barons restoration. 1970 fasty.
More updates now as we spent the evening in the workshop.
I spent my time prepping the inside of the doors for primer and the under bonnet.
Right is before, left is after;
And while I was doing this Mick polished up the shell.
Started with this;
Then began to sand with 1200;
Till the whole lot looked like this;
Next was the 4000 grade with a wee bit of water;
This was followed by a polish with the course then fine cutting compound which left it looking like this;
Just check the depth of shine;
And it feels like a pool ball
Started with this;
I will finish it some day!!
Rust free imports direct from California;
www.route9autos.co.uk
The west of Scotland VW club.
http://vwscotclub.co.uk/forum/
"...And it feels like a pool ball..."
Nah - that's just because you haven't got any fingerprints left!
I got my wife to wet-and-dry the louvres in the rear wings on my Fastback - never misses a chance to remind me, wearing her fingers to the bone.
(Green with jealousy, me; where do you get your energy from?)
Im not quite sure where the energy is coming from, must be the excitement of seeing it coming together and by the way, wet and dry is apparently a dirty word in the body shop, there are all sorts of sanding materials which make the job a bit easier.
Another update for y'all, not a very exciting one thought.
As we are in the middle of the final prep, every job done here will make the final finish better so the panels which have been repaired were pulled out for block sanding tonight.
The panels were given a light covering of guide coat, this stuff;
(I moved onto the spray as the powder was running out)
And then block sanded. This is the rear wing about half way through (closest to the camera is the sanded part)
I also got the front wing done tonight;
Mick was in the spray booth priming the allready repaired drivers door and drivers side front wing;
While I was getting the front wing block sanded Mick made a start repairing the passenger side door;
And once dry I made a start on sanding the drivers side door.
Mick got the passenger door fixed and headed back into the booth to get it primed before we packed up for the night;
Back up next week and hopefully some of the panels will start to see paint.
Time for the next instalment.
Tonight was pretty mutch more of the same, block sanding and prepping.
I got the passenger door sanded;
While Mick was in the booth painting the backs of the wings;
And once the backs were dry I got the front drivers wing sanded while Mick worked on the rear offside wing.
We wont be working Thursday this week but hope to get all day Saturday spent on it.
Dave
Dave
Well, the wait for Saturdays update is over.
I started at the garage at 9 (ish) this morning, Mick was busy with customers so no painting gor done but it did mean I got a chance to get started on some of the little jobs that will make a big difference.
With the inner front wings now nicely painted the front suspension, steering and brake hubs were looking grotty so a coat of black paint to tidy them up;
This will be dirty again after a couple miles drive but might as well look good to start with.
I then moved on to getting all the masking tape off the wiring and routing them around the under bonnet before I started waxing;
Then it got messy with the black wax;
Finishing up with fitting the petrol tank;
While the wax gun was out I used clear wax and the injector hose to coat the inside of the sills and door pillars before fitting the nozzel back on and giving the rear inner wings a light* coat.
Another jump closer to finishing and we might get another shift in before the workshop closes for christmas but it depends how busy Mick is.
Dave
*Obviously in my mind "light" is open to interperatation
Dave
Well, next update time.
Started with a load of little jobs tonight, wiring in the door switches, washer pump and fuse box then fitting the fuel filler kneck that I painted on Saturday;
Then onto more sanding and panel prep. All the wings and doors are now done so onto block sanding the bootlid.
This is the surface I started with (this was the roughest panet, the rest were smoother) for comparison;
I covered the panel with guide coat;
And as you sand the high pionts get lighter and the low points stay black;
Keep sanding untill the black dissapears and you get a nice smooth finish;
Once that was done I finished the night by doing more prep on the inner bonnet surface;
As the workshop will be closing for Christmas at the end of the week this will be the last update of 2007 so Merry Christmas and look out for more updates in the new year.
Happy new year everybody, Christmas is over and I was back up to get more work done tonight.
I spent the evening doing loads of little jobs like re-mounting the regulator, heater pipes, door edge trim, rear wing seals, headlining, door latches and loom cover.
While I was doing this Mick took the driver side panels from this;
And added some colour;
After 3 coats of colour and 2 of laquer they looked like this;
Shiny? You bet, this was taken from across the room;
Back up Thursday hopefully to start mounting the painted panels.
I was off today so I went up to the workshop a few hours earlier and as you will see it really paid off.
Job 1, fit front wing;
Job 2, fit door;
Job 3, spend about 2 hours stripping old door and transfering the lock, outer scraper, inner scraper,check strap, felt and window winder into the new door. Couldnt complete the door as I want to paint up the 1/4 window frames before fitting so moved onto......
Job 4, way the inner side of the rear wing;
Job 5, fit rear wing then stand back and look as its almost a car again
While I was doing this Mick was in the booth adding paint to the passenger side panels;
Its all coming together quite quickly now but still loads of wee bits to do.
P.S. I really need a complete fuel flap operating cable with knob if anybody has one.
Job 2, fit door;
- nitro_warrior
Phil Evans had a NOS fuel flap release - maybe not the knob. Look at the parts for sale. Lorenzo posted a photo of it on a NOS front panel.
See viewtopic.php?t=1517
Cheers guys,
Micks been busy today, thats the panels flatted back;
Then polished;
Dave
P.S. I found an NOS cable release on VZi about 2 minutes after posting the request, aint the internet amazing?
Then polished;
Dave
Went up a wee bit earlier again today and managed to get a good bit done.
I fitted the wing beading to the drivers side which I wasnt fitting until Mick had polished the paint to save polish from getting stuck under the rubber.
As the panels are now polished I started with this;
And using a roll of wing beading:
I managed to get the drivers side finished off;
I havent decided yet if its staying black or if I am going to try and make it green as it was before.
I then waxed up the passenger side rear wing and fitted up the passenger side panels so it really does look like a car again;
More on Thursday I hope.
Dave
Dave
The wing beading is T section. I know what you mean about the black looking not too bad but I am going to wait until I see it in daylight before I decide for definate.
I had to use the original green beading between the back wing and vallance as the new stuff was too springy to get it sitting nicely.
Time for a new update, lots of little jobs that seem to take forever and a couple of biggies.
I fitted up the windscreen skoosher nozzle, fuel flap release and finished off the wing beading on the passenger side;
While Mick repaired the bonnet;
Primed the outside and painted the inside;
The bootlid also recieved a coat of paint tonight;
I hope to get up for a few hours tomorrow so watch this space.
Right you lucky people, here is the second update in 24 hours and its a goody.
I had a day off work so I headed up to the workshop at lunch time and started by fitting the trim clips along the side panel;
I sourced a brand new set of trims so it was just a case of carefully unwrapping them and figuring out which was which;
Once fitted up I spent a bit of time getting the door lined up properly and Im pretty chuffed with how it looks;
Now here is the biggy. I spent a good 3 hours on this as its really surprising how long each wee job takes and even more so when trying not to scratch new paint. My car has a face again;
I still have a few bits to finish off at the front but its looking great, just wish my new bumpers had arrived from the states as the ones I have are showing their age a bit.
I also need to decide if I am ordering up black and silver plates;
Seems a shame to take off the plates it has worn all its life but black and silver might suit the car better.
- Angelo Amato
fasty
FANTASTIC job Dave - well chuffed for you.
I know what it's like, alot of hours and hard work, but looking GOOD !
Angelo
Angelo
Cheers mate.
A HUGE thanks to Mick who went to the workshop and got the last of the painting done.
The top of the bonnet, torsion bar access covers, number plate light and fuel flap were readied and painted;
And the boot lid was flatted back;
and polished up to a shine;
Cheers for saying so Nidge, I'll just be happy to get it back on the road.,
Time for Tuesday nights update.
I started by masking off the front wings so that I didnt get evo stick on the paint while applying the bonnet seal;
With that in place;
I moved on to the boot lid seal;
And while I was sniffing the glue I got the edges of the headliner stuck back down around the windows;
While I was glueing Mick was polishing so once I had finished off we got the boot lid in place;
Followed by the bonnet;
And as you can see I decided to go for black and silver plates.
With that in place;
