project 72 fastty
cheers nidge,going all out to do something a bit different.finnished deguttering other side of roof tonight only door and wing to do then its sorting out both bottom corners around the engine mounts.been in touch with type3 detectives today about the front bumper,should be here in a couple of weeks.cant wait to see how its going to look with all the bits bolted on,more pics soon.
early fasty bits needed
more welding done tonight,done all passenger side rear(around engine mounts)and smoothed vent of other back wing.rear tyres came today 235x35x19,look mint on the new rims and seem to fit with no problems.i have a full stainless steal 4 into 1 and j pipes with stainless back boxes, i would like to swap for a good pair of heat exchangers. if any ones interested please let me know,more pics soon. cheers fastty
some more holes(been plenty of them) and repairs.the wheels have been photo chopped(they are actual size with just the centres beening masked) but the ride hieght is for real.car looks awsome with the 19".have lowered it one more outer spline +raised it one inner spline.will lower front another spline tomorrow,but waiting for front tyres to come so cant set front ride hieght properly.this week will be all the body work and hopefully in premier by weekend,once this has been done and all the wheels are on then i will reveal how she looks.more to come
done a bit more tonight,there was a clearance problem at the rear of the arch on the tyre.to remedy the problem i cut the arch lip of and moved it backwards 55mm,thus stretching the wheel opening enough to clear the tyre.i then rolled the arch lip to gain even more clearance,lot of work,i bet no one will even notice it.more pics tomorrow
most of the rear window was rusted out at the bottom.
once all the bits were made and welded in this is how they looked
also smoothed the recess under the boot lid,and streched the other rear wheel arch.just the tubs to weld in the rear and a new rear valance.
cheers for all the comments it all helps to keep the project rolling on.more pics later in the week.
- Angelo Amato
fasty
fantastic job and i see you are in the NW like me
look forward to seeing it.
nice to see another fastback saved from the grave, as it seems it needed quite a bit of work to put right.
Angelo
Angelo
if it wasn:t for the new front clip, i think i may have broke it for parts.but there has still been a lot of welding(just like some of the other projects on the forum)just done some of the last welding tonight.can now start linning all the panels up before i can do any body work,cheers
finally started on the turbo conversion.got one side of the exhaust system built and got turbo sitting in the correct position waiting for a couple of mounting flanges,but should be here this week.
has any one got a twin choke weber carb for sale,if so please let me know thanks.heres some pics so far.
