project 72 fastty
vwfye
Re: project 72 fastty
Post by vwfye » 15th May 2021 - 10:12pm
Very nice! How is the shift location or is it paddles?
fastty
Post by fastty » 16th May 2021 - 9:40pm
shift position is pretty much as it should be, no paddles.
early fasty bits needed
Post by broady_6 » 7th June 2021 - 9:59pm
You are annoyingly good! that looks like it should have been in that chassis all a long!
fastty
Post by fastty » 16th January 2022 - 5:56pm
finally back on the fastback, hopefully now on it until its done.
dug it out and straight on it. going to finish up the rear body mounts and then the body can come back off for final welding and sanding on the chassis.
more soon.
vwfye
Post by vwfye » 17th January 2022 - 3:09am
If I wasn't in so much awe, I would be jealous! Great build!
fastty
Post by fastty » 19th October 2023 - 9:02pm
its been awhile and yes i am still on with the fassty build all be it much slower than i would like .
moved house a year ago so its been full bore into that and i am just having the garage extended so as soon as the fassty is painted it can come home to be built up. this i am hoping is the motivation i need to get on with the build.
Post by broady_6 » 11th November 2023 - 8:58pm
Looking forward to seeing more.
fastty
Post by fastty » 12th November 2023 - 8:53pm
cheers broady,
finished up both of the front end closing panels do today and also got the brake flexi mounts welded up . also got a couple of braces welded to the front hinging bonnet mech to add some extra support . at least some progress is being made .
will see if i can add some pics .
fastty
Post by fastty » 12th November 2023 - 9:10pm
couple of pics for you .
Ant B
Post by Ant B » 14th November 2023 - 11:51am
That is one awsome build project sir.
Thank you for sharing.
1967 Karmann ghia
1972 412 variant
ex AA van
vw caddy pickup mk 1
Post by broady_6 » 18th November 2023 - 10:04am
Love the bonnet extenstion, its going to be tough to tell is its a normal size fasty or not after youve done
fastty
Post by fastty » 18th November 2023 - 4:09pm
cheers Ant B,
i am hoping the only way you can tell is if it,s parked next to the same year car. want it to look stock .
going to need a few bits of bright work in the next few weeks as all the chrome is going to be painted so dont want to buy new so will get an add in the wanted section pretty soon .
Aaronslimvw
Post by Aaronslimvw » 18th November 2023 - 7:14pm
Awesome job!!
fastty
Post by fastty » 3rd December 2023 - 4:12pm
bit more done, on with gapping all the panels.
started withe the passenger wing and door . set the door with a nice 4mm gap to the sill then welded the edge of the wing to get the same 4mm gap down the door front edge. after a bit of cutting and welding got the wing to sit right with the door and the scuttle panel under the window screen . wing fits front panel ok so its now on to the drivers front wing and door and then i can set the back wings in position.
in the last pic you can see just how long the front now looks .
Post by broady_6 » 3rd December 2023 - 6:47pm
A very nice fit, as good as VW did
fastty
Post by fastty » 10th December 2023 - 7:12pm
top of the drivers wing done today but i still need to make sure door is in the correct position before i can finish the gaps as the other side.
been offered a 3.5 rover lump with fast road cam, big valve heads and a 4 barrel carb this week that is ready to go out of an early tvr at right money so would save me a fair lump over rebuilding the engine i all ready have.
Post by broady_6 » 24th December 2023 - 7:58pm
Anything to get it on the road sooner!
