My 64 Notch
My 64 Notch
Well, I have got the Notch in with Classy Campers in Weston Super Mare to get that bloody drivers side door resprayed. It was the one thing about the car that really bothered me, whilst it was in there I decided to have a good poke around and sort out anything else that may have needed doing. The sills were looking a bit crusty so they are going to get a looking at, as well as some bubbles on both doors.
Here she is......................getting naked, ready for a rub down!!
Passenger side sill.
Looks even rougher up close!!
Get the paint off and see what is going on...
Hmmmm, some of these previous repairs aren't to the best standard.
Nothing too much to worry about. A panel is en route from Type 3 Detectives for this side.
All the rot is to be cut out and replaced with fresh metal.
Ah bliss, this end of the sill didn't benefit from previous welding, simply plug the area with filler!!
The bubbles along the bottom of the door have turned into this.....
One previous repair on this corner of the door was ok, lead loaded, shame about the later work.
Now round to the drivers side.
I didn't think this side looked as bad........
Get the paint off for a proper look. :affraid:
It could have been worse, this just needs a sheet panel making up and welding in.
Quick, sweep it up before anyone comes!!! :lol!:
Looking better, should be good for a few more years.
Especially pumped full of Waxoil when it's done......
Up in the air it is solid. No rot at all in the floor etc.
I've finally seen the light. Well, 2 lights, 2 6v lights on the front of a 64 Notch!!!!
Cheers fella.
The other area that needs doing is the front clip side of the spare wheel well. It has been raised now as it was lower and I think that area ground out a lot hence it has blown through at the bottom. Not got any pics of that yet but hope to have some for the next update.
When the paint is done the engine is coming out to sort the oil leak. First job will be to tighten the adjustable push rod tubes and then check the crankshaft oil seal.
I am going to stick with the 009 and go 6v pertronix in that, so that will sort the timing, and then put the 5x130 discs on the back to lose the adaptors.
135 tyres to replace the 145 on the front will give a tad more tuckage and I have had the arches rolled to maximise clearance.
Just on the hunt now for a 6v oil temp gauge.
One sill sorted with fresh metal and a skim of filler. Looking much better I think.
And some paint going on, this paint actually matches!!
The other dodgy area was the front valance. Previously I think the car had been lower and this point had regularly ground out. Hence it had blown through with a bit of local rust.
Out you come......
Shaun made a replacement panel up.....
....and slotted it into place.
And covered up with some paint.
The passenger side is next to get some paint on and then it's a few mechanical bits and bobs.
Ie rear discs, oil leak and a couple of other little things.
Should be back with me soon.
Out you come......
Another update on this then.
Went to have a proper chat with Ady yesterday.....
The engine was dropping oil whenever it was warmed up, not a huge amout but it was annoying. So whilst the car is there it is getting sorted.
So, whip the 1776 out.......from here.......
to here
It would seem the suspicions were correct, crankshaft oil seal had gone.
Happily, despite there being plenty of oil in the bell-housing the clutch etc was okay.
Unfortunately we have discovered a hairline crack in the gearbox casing. I am awaiting news to see if a local chap will go out to Ady's and Tig the casing for me.
It's booked into the booth for Thursday, then it is just a case of getting the 6v Pertronix in and sorted, quick tune up and then get the rear discs on.
Bit gutted it won't be back with me for a local show on the 7th but I am hoping to have it sorted for Vanfest. Might need a couple of late nights then to get the couple of accesories etc I have for it on there!!
to here
Take care welding the gearbox - it's magnesium alloy, and if it catches fire, you will have a job putting it out. You won't do it with water, as that just breaks down into flammable hydrogen gas!
I believe there are ways to weld it in an inert atmosphere, but probably not the sort of thing an average welder would be able to get access to - I don't think the gas flow from the TIG would be enough.
Mr scoops,On the side where theyve replaced the whole outer sill-any chance of a pic or two of how theyve dealt with the bottom of the A & B posts?..and how did they do it without taking the wings off?..i'm about to do mine (having promised myself all summer that the first week of sunshine,i'd get on with it...!
The latest update. Apologies for the pics, they are straight off an iPhone.
The next problem was the bubbling coming through on the bottom of the passenger door, rather than try and source an NOS door or a solid replacement the rot was cut out and a new section of skin was fabricated and let in.
So it was out with this
Then this replacement steel was made up to go in to replace where the dreaded tinworm had settled.
Which got the door looking like this.
The corner then received a little bit of 'loving'
And then it was all tidied up
The last bit of bodywork to be done was a quick look at the passenger side sill.
So it was off with a wing.
And let's see what is going on.
Off with the outer sill
Not looking too pretty is it???
So the whole inner sill had to come out as well!!
A new peice of tubing for the heater channel piping was made up.
And then new inner sills were made up
And then the floor section was let in.
Looking better.
And on to the T3D outer sill now....probably the only bought replacement panel used. A testament to the skills of Shaun etc out at Classy Campers.
Oooooooh, sexy!!
Just a bit of grinding down to do
Looking better.
Oooooooh, sexy!!
- nitro_warrior
The latest installment.
Engine out (again) to get the gearbox out for welding and to change the clutch which we decided may as well be done whilst we are there.
Bish Bosh
And then out with the drivetrain.
Oooh, look at me horns!!!
A localised clean up was required to be able to weld the hairline crack.
Initial attempts to weld the gearbox casing were not very succesful. A pook of material was just forming on the surface of the casing. Take 2, using some material cut from a scrap gearbox, and VOILA!
And it is now all sealed up. Woo Hoo, no more leak!
Whilst the drive train was out the rear drums were whipped off and changed over to discs. (The rear drums are for sale as complete units by the way). I don't have any pics of the conversion at the moment. Needless to say they look great. The master cylinder has also been swapped over to a Porsche unit to increase fluid displacement and therefore give me much improved brakes.
The old girl was then loaded onto a trailer and went off to the spray booth.
It is to be sprayed this morning so things are looking good for later this week.
The engine has also been given a tune and the carbs re-balanced as well as the timing all sorted.
The next pics should be shiny ones!!!
Bish Bosh
I must have it ready by the end of October, thats the target date I have just got a set of orig wheels all blasted and painted for free! so will add them at some point.
Just painting the last engine bits, clamps etc and a bit more porting and polishing of the heads etc and then its build up.
The exhaust is a one off custom which tucks away to alow for the lowness, although it will be higher than before due to the deep sump
Gonna be some ace notches around the south west soon! Will come and have a nose at yours at Oktoberfest
Chrome doesnt get you home...
