71 rhd square 49k 2 owner
volkswalker
Re: 71 rhd square 49k 2 owner
Post by volkswalker » 8th April 2011 - 10:44pm
well managed to get the beam back on today with the help from daz the celica turbo builder...
now some of you may not like this part of the resto because ive butchered the lower support arm that the beam clamps to but alas ive kept the piece ive lobbed off if ever i wana revert it!
this part of the resto is to rid the underside of the beam of the butt ugly bolt that clamps the bottom of the beam together and protrudes towards the road and whacks it of lowered on 2 splines and 3 splines...well thats just whackwhackwhackitywhack....
this mod allows me to go 3 splines if i want and know ive gained a good inch (ooeer) on the clearance of it....
this arrowed part which is the lower beam grasp needs chopping a tad
like this
then take the clamp itself and weld a piece of metal that fits inside the rubber clamp....the red crosses show wer ive bent it to curve around the beam
heres how it looks without the beam fitted
a good tip is to grind the lip off that the new metal clamp wraps around for maximum clearance....dont be shy get it off
set it up 4 welding
before welding make sure you get the upper bolts and clamp all nice and tight so theres no movement....looking good
and finally weld the new part of the lower clamp to the beam holding arms...i read a mod from a link on type 3 that welded one side and used a bolt and nut the other but ive decided to weld both sides...if i ever have to remove clamp ill simply cut the weld off releasing the clamp....
but remember i intend to go beetle beam with air ride in the near future so the lower beam holding arm isnt used when using a bug beam...
so here we have a non whacking beam that can go 3 splines...
got to do other side tomoz!! red arrow shows wer old ugly protruding bolt was and i gotta grind that weld flat too
volkswalker
Post by volkswalker » 19th April 2011 - 7:17pm
well well well !!!!!!!!!!!!!!!!!!!!!!update!!!!!!!!!!!!
after having spent many hours trying to get the rear at a height im happy with and
more importantly EVEN..... im now super fast at stripping and re fitting the rear suspension!!
also the newly modified beam is 3 splines with no clamp bolts to hit the tarmac
MOT thursday!!!!!!!!!!!!!!!! 1pm!!!!!!!
just gotta get a side light bulb tmrw! I blasted it up and down my street today and
slammed the brakes on with no veering to the left or right and jeez what good brakes!!
im used to 4 drum brakes not discs and calipers (and new ones at that)
theres a very small amount of play in the o/s front drum and its the bearings i think
and i pick up a set tomorrow for £8.00 cos the bearings i need are the same as a rear
on a Mk3 polo/golf!! (read it type3)
so 8 months of hard work is nearly paying off and once I get the ticket I can start
sorting the interior and prepare 4 paint next month!!
Im waiting 4 my 165.45.15 tyres to arrive for the front and will fit these after weekend
and also them aicd dipped gt steeliz i got for a song
check beam wahay!!!
volkswalker
Post by volkswalker » 20th April 2011 - 7:04pm
plates on and ready 4 tomorrow!!!!!!!!!!!!!!
Smiffers
Post by Smiffers » 20th April 2011 - 10:18pm
Looking cook friend:) good luck with the MOT!
volkswalker
Post by volkswalker » 21st April 2011 - 7:23pm
wahaaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy:D
no advisories....but the V5 stated PLG not Historic so gotta go in person to my nearest DVLA office and get me V5 changed and collect tax disc....thats 1 hour away and cant go til tuesday!!!!!!!!!
see yo'all at stanford tho! :thumbsup:
fastygaz
Post by fastygaz » 23rd April 2011 - 8:28am
Love the cheesy pic dude!! :D
If it ain't King James it ain't bible y'all........
Paul Hayward
Post by Paul Hayward » 23rd April 2011 - 6:43pm
well done! 8) ...been following all the hard work you been putting into this :D ..ENJOY! 8)
Paul and Kat
volkswalker
Post by volkswalker » 23rd April 2011 - 10:27pm
barndoor deluxe wrote:well done! 8) ...been following all the hard work you been putting into this :D ..ENJOY! 8)
thanks mate!!!!!!!!!!!
not much feedback on my thread really considering ive done 7 months of nearly everyday to get it
to this point!!!!!!!!!!!
but hey peeps are busy i guess!!
nice 2 get it tho!
volkswalker
Post by volkswalker » 27th April 2011 - 5:46pm
ok ive managed to sort the ride comfort...
fronts are 165.45.15 with 18 psi
rears are 155.80.15 with 28 psi
short shocks front stock rear....
went 4 a blast earlier and wow what a difference!!!!
its just a tad off the comfort of my dropped spindled 59 bug last year...
1st proper blast in my newly mot'd slammed 71!!!!!!!!!!
im buzzzzzzzzzzzzzzzin!!!
and its our club meet tonite so wahay weez goin down there!!!
volkswalker
Post by volkswalker » 29th April 2011 - 6:07pm
ffs!!!!!!!!!!!!
got this today after the near disaster last month
and then today fredshed popped round and we changed the oil...went 4 a blast down the seafront.... i then decided to whack £30 of fuel in as id been running around on near empty since passing mot...
walking back to the car and WTF!!!! fuel dripping off beam....
only live less than a mile away from station so drove home, jacked it up and managed to save most of the fuel!! looking at the tank i see there is a hairline crack thats been well gunked over!!
panic!! stanford show sunday!!
quick ring round and broady tells me that gaz has a new one in Lincoln so im there tmrw to get that and get it fitted and go for the 3hr drive sunday morning to the show!!!!!!!!!
anything else im thinking!!!!!!!!
Paul L
Post by Paul L » 29th April 2011 - 10:56pm
nice work! great to see it running (but not leaking!)
1972 411 LE Variant Auto
1971 411 LE Fastback
volkswalker
Post by volkswalker » 30th April 2011 - 3:55pm
ok im all set for the 3 hour drive to stanford tomorrow!!!!
maybe see you there!!!!!!!!!!
volkswalker
Post by volkswalker » 1st May 2011 - 12:49pm
fueled up 5.30am...met up with andy in the bay....
headed out on the M180 and cruised at 50ish and all was going great....
just passed scunny south junction and lost all power...
no revs...engine turning on key...
oil spray all over rear but not too much....big collection of oil on the nearside
heat exchanger....after 30 mins i checked the oil and theres still plenty left and its
between the markers.
AA got me home and ill investigate the reasons another day im knackered at mo and
cant be arsed....
anyway heres a few pics....
shame we never made it but least we are ok!!
the wind was biting even tho it was sunny!!
got towed off the motorway but the dolly couldnt get the front end on...
it was 2 inches off being hooked up but the beam prevented it
big truck did the job
Post by Editor » 2nd May 2011 - 1:35am
Shame about that.
Yes, the wind was quite a nuisance at Stanford Hall - tied the gazebo to the fence, and so it was only the papers that escaped from time to time.
volkswalker
Post by volkswalker » 2nd May 2011 - 2:20pm
compression testing gonna be done in a few days...
probably be partial engine seizure according to some advice..
engine out thursday...see what the craic is and go from there...
I WILL BE BACK thats 4 sure
Clockwork
Post by Clockwork » 3rd May 2011 - 8:50pm
gutted for you pal, after so much hard work!
Was looking forward to seeing this ride at Stanford, now I know why I didn't...
Hope you get it sorted dude...
fastygaz
Post by fastygaz » 6th May 2011 - 8:51am
Jesus dude, you ain't having much luck with the square...and after driving over at 4 in the morning for a tank!! I really thought the neighbours opposite would've called the Feds...they stick their oar in everything else!! :x
Still, I know you'll get it sorted buddy, and still looking forward to seeing it!!
Take it sleazy
Gaz
volkswalker
Post by volkswalker » 7th May 2011 - 10:51pm
fredeerz popped round and worked the magic on the square to
try and work out why it failed last week, and it appears its the condenser!!!!!!!!!!!
fuel lines good, carbs gettin fuel, plugs n points ok.
coil could be faulty but fredderz brought his and he worked out that the condensers fooked.
bought a new dizzy cap....condenser arrives monday so ill get that swapped
and hope to hell it does the job!
oil spat was rocker cover avin a moment...
so afterall my worst fears it appears it could be as simple as that.
if it runs then ill get some miles on her asap and run it until anything goes wrong and
if the engine keeps going fine then ill leave it in until winter until i do the rear end resto...
and to pass the time ive given her a new look inside...wow its bright ;D
volkswalker
Post by volkswalker » 12th May 2011 - 10:24pm
ok ive been tinkering last few days...got new condenser and dizzy etc but waitn 4 fredderz
to pop monday and work his magic and get the damn thing running i hope..
skeggy nearly here and gotta take it or ill go crazi :evil:
so after i damaged the ozzy passenger door and the mechanism not fully working
i decided to check out the spare pass door i got with the square...never really had a good look at it..
its in good nick, needs a small piece welding at some point (winter) and the seals good.
it had a smashed quarter so yesterday i removed the quarter from the ozzy door and also the main glass..
managed to smash the main glass when refitting it doh! (did a steve) and luckily had a spare.
fitted that up and the door fits lovely with lock working and both windows and door card fits spot on.
ive got 2 pass doors and a driver door spare now...
the ozzy driver door had them 5 small holes in for chrome trim so today ive welded them up and skimmed a lash of filler and its come up trumps...so a better day today than yesterdays calamities.
Post by Editor » 12th May 2011 - 10:28pm
I surprised myself when removing the support channel from a door window - bang! and lots of bits of glass everywhere. It only needs a bit of a scratch to make the tempered glass explode, yet you can hit it hard with a fist! (but don't do that).
volkswalker
Post by volkswalker » 12th May 2011 - 10:32pm
Editor wrote:I surprised myself when removing the support channel from a door window - bang! and lots of bits of glass everywhere. It only needs a bit of a scratch to make the tempered glass explode, yet you can hit it hard with a fist! (but don't do that).
i was tapping the bottom of the window so so gently with a small hammer (should have used the rubber mallet like a plonka)
but it was so gentle i didnt think it could make the window explode.
ive spent a good 45 mins picking glass out the grass and red brick drive!! and ill continue to see glass
for the next few weeks im sure!!
volkswalker
Post by volkswalker » 13th May 2011 - 7:58pm
okiz got front bumper back on today and gave the underside a real good lashing of
stone chip in loverly white
and heres shakin stevens' GREEN DOOR!
stuvw
Post by stuvw » 14th May 2011 - 11:56am
good work buddy n hope ta see it at shows soon :)
volkswalker
Post by volkswalker » 16th May 2011 - 12:32am
volkswalker
Post by volkswalker » 16th May 2011 - 7:43pm
got her going today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D
condenser!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :arrow:
woopwoop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :thumbsup: 8)
