1972 fastback. nwe 532k
col1600
Re: 1972 fastback. nwe 532k
Post by col1600 » 12th September 2016 - 7:48pm
fantastic work mate. great sheet metal skills there..
You Love It.!!!
kaddy
Post by kaddy » 12th September 2016 - 8:58pm
Thanks Colin, its like a journey of discovery restoring one of these.
More rust on the other rear wing
New section cut , shaped and welded in.
kaddy
Post by kaddy » 12th September 2016 - 9:22pm
Rear wing arch removed and replaced with new metal
Wing corner trial fitted
col1600
Post by col1600 » 16th September 2016 - 1:41pm
:thumbsup: :thumbsup: :thumbsup: :thumbsup: keep rolling cant wait to be driving 2 in a row of fastys, that get some looks in tullamore!!
col..
You Love It.!!!
kaddy
Post by kaddy » 16th September 2016 - 8:54pm
Yeah.....I,ll keep the pedal to the metal :nod:
kaddy
Post by kaddy » 17th September 2016 - 8:42pm
Drivers side heater channel inner part , welded in today, and worked well.
Pics to follow. next is to cut out the passenger heater channel, offer in the
new one for marking, and final fabbing, then weld in too.
Major hurdle over once this is done. Expect to have new channel in by this
day week.
Then pics to follow.
kaddy
Post by kaddy » 24th September 2016 - 8:45am
Found more rust under the nose either side of the spare wheel tub.
Image[/url]
Made these panels to replace the rusty ones.
Cut them out
And welded in new metal.
Spare wheel tub has seen better days.
So a new forward facing section was made up.
kaddy
Post by kaddy » 24th September 2016 - 8:53am
New side panels at spare wheel tub welded in.
col1600
Post by col1600 » 24th September 2016 - 9:07am
Excellent work.. She's gonna be as good as new..
You Love It.!!!
kaddy
Post by kaddy » 24th September 2016 - 12:39pm
It,ll be solid anyway :-)
kaddy
Post by kaddy » 24th September 2016 - 6:57pm
Wheel tub repaired
col1600
Post by col1600 » 24th September 2016 - 7:02pm
Your spending way to much time out in that garage!!!
Keep it up.
You Love It.!!!
kaddy
Post by kaddy » 24th September 2016 - 8:18pm
:badgrin: :badgrin:
Thats only because I am an out of work artistic joiner, and at 60 cant even get
an interview for a job................
So fasty is keeping me sane :)
col1600
Post by col1600 » 24th September 2016 - 8:25pm
Think your looking for the wrong job title, you should be looking in the resto direction. That way you can move out to the garage full time.
You Love It.!!!
kaddy
Post by kaddy » 24th September 2016 - 8:52pm
Aye....and get paid for the privelage.
kaddy
Post by kaddy » 26th September 2016 - 10:16pm
Front clip repair panel trimmed for fitting to bottom of clip.
Now welded in and rough ground.
kaddy
Post by kaddy » 3rd October 2016 - 10:59pm
Front fuel tank, suspension support section. Panel fabricated from 2 sections,
To replace this,
kaddy
Post by kaddy » 3rd October 2016 - 11:04pm
Rust cut out.
New panel fabbed up.
kaddy
Post by kaddy » 5th October 2016 - 9:44pm
Wheel house panel pleat completed,
Imagel]
Front bulkhead corner rust damage.
Rust cut out and cleaned up area.
Repair panel made.
Another view of the corner repair panel.
vertical corner pleat continued on panel.
And finally welded in
kaddy
Post by kaddy » 8th October 2016 - 7:37pm
Rust damage cut out from rear left hand side body support mount,
Bottom support plate replaced.
Plate to go in above this lower foot,
2 mm stiffener plate,
Area cleaned up for stiffener plate.
Stiffener welded in .
Bulkhead cover hammer formed.
Bulkhead cover welded in .
kaddy
Post by kaddy » 10th October 2016 - 8:07pm
Extensive rust under driver rear wheel arch, just ahead of the engine bay.
Bulkhead corner removed to see whats beneath.
View through bulkhead into the back face of the engine surround metal.
It has to be cut out too.
New engine surround metal panel fabbed up, ready for grinding.
R/h piece
kaddy
Post by kaddy » 11th October 2016 - 7:05pm
New panel made for the right hand side of the engine bay, including the bulkhead piece, at the back.
[Image]
kaddy
Post by kaddy » 13th October 2016 - 7:32pm
More rust to cut out.
New panels made to replace the rusty ones.
Rust removed, and cleaned up area.
Lower wheel arch panel installed.
Large lower back panel, and drain shute for the wing installed.
Large upright tail end corner panel top repaired.
Post by purplepeter » 13th October 2016 - 9:48pm
Are You happy that the drain chute/flap is in the right place?... It's difficult to get the orientation of the pics but it looks wrong?
kaddy
Post by kaddy » 14th October 2016 - 12:06am
I am . Its approximately just below the engine mounting location.
I,ve referenced the location from the original, albeit rusty remains.
I,ll trya and take a better pic tomorrow
