1972 fastback. nwe 532k
kaddy
Re: 1972 fastback. nwe 532k
Post by kaddy » 6th April 2018 - 9:17pm
Good old clean up of the front boot area, and first coat of primer. I,m
suprised that things aint looking too bad at all considering the state it
was in .
So all in all I,m happy enough with how its coming along.
Passenger side wheel bulkhead.
Again passenger side view of the bulkhead.
Front end view.
View from the driver side.
View from the passenger side.
Passenger side .
Again passenger side view.
As the shell is currently suspended from the roof of the garage, ropes and web belts may
be a bit confusing. But hopefully it wont be up there long.
kaddy
Post by kaddy » 7th April 2018 - 7:35pm
A bit of L90D colour is starting to make all the difference.
Post by broady_6 » 9th April 2018 - 9:48pm
looking damn good! home stretch is well under way
kaddy
Post by kaddy » 9th April 2018 - 11:16pm
Its amazing what a bit of slap does to the old girl :lol: :lol:
Yeah she is looking like a youngster again :D
kaddy
Post by kaddy » 19th April 2018 - 7:15pm
Spent 4 hours taking out the rear window to prep the ope for the new paint and seals.
Interesting 4 hours, thanks to some muppet using Tek seal to try and seal a leaking rubber seal
instead of buying a new seal. Ended up having to completely cut out the old rubber seal, to make sure the
glass stayed in one piece, and not thousands.
But mission successful.
Rob-type3
Post by Rob-type3 » 22nd April 2018 - 11:44am
This is looking good!
kaddy
Post by kaddy » 24th April 2018 - 7:51pm
Some more updates on how the spraying on the shell is progressing.
Rear drivers side louvre corner.
Roof section viewed from passenger door towards the rear.
Front clip.
Rear clip.
Rear roof corner again showing a good finish ready for final polishing.
Near completed shell hovering over its long lost chassis.
Rear pasenger side corner
Front clip after more wet,n,dry finishing.
Roof section corner progressing nicely. If I can finish this well all over,
I will be well pleased.
Rear clip.
Rear clip above bumper level.
Another bit of work needed here before its ready for final finishing.
Front clip after some final wet,n,dry finishing.
Front clip looking well and ready for some final finishing.
Post by broady_6 » 24th April 2018 - 9:26pm
:thumbsup: :thumbsup: :thumbsup:
kaddy
Post by kaddy » 24th April 2018 - 10:19pm
Here is what I used to seperate the seals around the front and back screen.
Its a shortened carving knife that I made when I used to make shoes, for cutting leather.
Slips in under the seal from outside, and then push in firmly to get it just under
the inner glass, not the seal. Then it slices the seal nicely, as its the thinnest part of the seal
thickness here.
Drastic but necessary to free my tek sealed windows.
Post by broady_6 » 25th April 2018 - 8:00am
Smooth idea, I just wrestled with a Stanley blade which got risky at times
kaddy
Post by kaddy » 25th April 2018 - 8:24am
I,ve done that too on occasions.
The carving knife cut down to a short stubby blade is a great job.
Its slim enough to slide into place with no damage, and its tough enough not to bend
at all under any pressure. And its broad enough to ad leverage if needed.
And 50 cents in the boot sale, how can you go wrong
kaddy
Post by kaddy » 25th April 2018 - 1:20pm
Playtime over, have to crack on.
But I couldn't resist the last polish with 3000 grit wet,n,dry.
Its a tactile thing
kaddy
Post by kaddy » 25th April 2018 - 8:59pm
I think I have now got a finish thats good enough for my needs.
After 5 coats of celly and wet,n,dry finishing using 1000, 1500,
2000,2500, and 3000,
And a quick coat of fine polish, I,ve got this.
And i'm gonna give it the thumbs up
Post by broady_6 » 25th April 2018 - 9:23pm
shiny!
kaddy
Post by kaddy » 25th April 2018 - 10:55pm
Yep, rather like the top of me noggin :lol:
kaddy
Post by kaddy » 26th May 2018 - 5:59pm
Back to business after me short rest.
Not much to report. Back seat area has been sealed over the welds.
As you can see, ready now for some stone chip paint.
Rear wing metal repair is cleaned up, and a light skim of filler to level out the repair
metal that was substantial. Not the filler, the metal.
The front end of the wing low down was well rotted.
At least now I have a useable wing. Now to the other wing which was in a similar condition.
Post by broady_6 » 12th August 2018 - 10:52am
How you getting on with the rebuild?
kaddy
Post by kaddy » 11th November 2018 - 10:51pm
Back on the clock now after getting sidetracked for a lot of house repair work.
New fencing perimeters, pvc soffet, facia, roofing work, ect,ect,ect
Have to keep the cook happy :-)
Now back to the interesting stuff. I see your car now has shine and colour,
mmmmm, nice..
jmarkha1
Post by jmarkha1 » 12th November 2018 - 5:05pm
looking v good - all that colour sanding pays off -
kaddy
Post by kaddy » 12th November 2018 - 6:39pm
Definitely preparation is the key to the finishing.
Post by broady_6 » 13th November 2018 - 9:45pm
Glad to see youre back at it! Whats the next part your going to tackle?
Mine does have a shine, but not a very good one yet.
kaddy
Post by kaddy » 14th November 2018 - 12:13am
Just remade the two long sections of the front bumper mounts. Both were serverely rusted
beyond use. So angle grinder to cut off the useless metal and refabbed new metal..
Then prime both back wings, and maybe a couple of coats of celly if I can get an
approprite heat source in my garage, sfaer than the solid fuel stove.
Dont want to blow me fasty up.
Any suggestions on the appropriate heat source that works for you guys out there???
Post by broady_6 » 14th November 2018 - 3:48pm
Infra red panel heater! Theyre £10-20 on amazon/ebay or try poundstretcher if you have that over there?
kaddy
Post by kaddy » 14th November 2018 - 5:13pm
That sounds good, I,ll look into that thanks.
I have a large solid fuel stove in the workshop, but I dont think its wise to light it up,
and spray celly in the vicinity
