1972 fastback. nwe 532k
Re: 1972 fastback. nwe 532k
Its in the same location as this.
And there are two more panels, to be fitted, before the wing cover panels.
The ope surround panel, and the top drain panel above this.
Wheel arch endpiece repair added, and airduct surround shroud,
New metal replacing rust in drivers side rear wheelarch.
New panels around air intake and tail.
Inner edge panel at engine bay.
Existing rust damage at body support mount that needs replacing.
Outer panel repaired at the base.
New body support mounting welded in and repaired.
Another view of the support bracket.
Bulkhead panel also welded in
Bulkhead now completed
More rust damage in the usual places in a type 3.
New roof repair section hammer formed with roof gutter.
Yet more rust removed from the inner corner,
New panel made to replace the support metal.
New support panel welded in.
New roof and gutter panel welded in.
Lastly new corner panel offered up for marking and then welding.
Final piece of the wing corner made up and welded in,
Rusty corner at tail end of the rear, behind the bumper, cut out.
Rust cut out.
New panel made up and welded in.
Drivers side rear finally finished
Rust cut out.
Heater pipe welded in.
Heater flap reconnected.
Drivers side heater channel completed bar the cill.
Left hand cill fitted
New cill formed,
Great work as always, very much enjoying following this thread
Appreciate the encouragement. Thanks.
I think i,m finally over the major parts of the welding on this car. I just have the two corners
below the front windscreen. And then a bit of tidying up and grinding. then priming and seam sealing
any new metal.
Long road to get this far i must admit. And there were times i thought...to hell with it.
But now I,m this far, i,m glad I stuck with it.
And the fact that you guys out there have some class cars after a similar venture,
kept me motivated.
So........more pics to come.
any new metal.
kept me motivated.
I,ve managed to remove the pbucket ransome notes, and replace them with all the relevent fasty details.
Thanks to Chevereto software imaging through my own website.
So after many months, and my daily aircooled hack heater channel replacements, i,m now back on track,
and fasty will be full steam ahead.......finally
How do you get the pistons out? Use a press with a collar on the piston flange? I guess it's all a matter of whether they have damaged the bores, or have serious corrosion. I've several pairs here that have seen better days, but I'm reluctant to label them as scrap until it's obvious they are.
Dont scrap them. These pistons were seized, but I successfully removed them all.
I,ll post pictures today of how i did them carefully
But basically....
Split them in two by undoing the four allenkey bolts, and then they seperate.
Take the caliper half that has the flexible hose and remove it.
Then put the piston side face down on a bench, and put WD40 into the caliper,
through the back of the caliper, where the hose attaches. And leave for a while
Now find a strong machined metal drift of good quality, similar quality to a pump shaft.
That will fit through the centre of the hole at the back of the inserted piston, and tap gently.
Keep checking after a few taps to see if the piston is moving. Dont bash the hell out of it.
This is an operation that needs patience , The other half is trickier
I,l go and get some pics...
Caliper face down showing the steel rod to punch out the piston, and the hole to insert the rod.
Rod inserted in position.
Rod position from inside caliper.
Position rod will strike inside piston edge.
Other caliper half with no hole access for rod.
Lubricate around piston, and raise caliper half above a solid surface.
And strike down hard with force onto a solid surface, making sure to strike flat .
Back of caliper half with no hole
Caliper half with hole for brake hose, that allows the slim metal drift.
It will require a large amount of blows to get movement started. But once it is keep wd40 applied.
Left and right taps on the piston will also allow movement against the seal in the caliper, which then allows
wd40 to enter.
Rinse and repeat.
But basically....
wd40 to enter.
Rinse and repeat.
I'll take a closer look at what I've got - some are clearly better than others. None of them has been in use recently, so I don't expect too much success.
These ones have not been in use for 3 years or more, and i cant
say for definite that when they were , they were 100%
Various pics of the cleaning process i used for my brake caliper components
Caliper placed into solution.
Connected up to standard charger
Power setting at 8 amps, and let the show begin
Woeking well at removing the rust, and softening the paint coat, which is hard and appears to be baked on.
Checked periodically, and taken out and brushed off with a wire brush, and popped back in.
Finally it appears to have done its job.
I do enjoy electrolysis, I really must do more of this! got a photo of the finished result?
Yes I do, but its after they were washed, cleaned, neutralised from the solution.
And then given 3 coats of hammerite;-)
New ball joints fitted today, and the beam fitted back to the frame head.
In the absence of the correct VW tool to compress control arms, I used a short robust sashcramp. It did the job great
as its extremely strong and easily closed.
Spindle positioned carefully, before clamp is released to allow balljoint to engage.
Sash cramp released and bottom control arm pops ball joint into spindle location, forcefully.
Now for the other side.
Onto the steering box now that both discs and new top and bottom ball joints are fitted.
Existing steering unit has some well baked crud on it and needs cleaning
Unit is in poor fettle on all sides.
Steering damper too, needs a tidy up
Between electrolosys on the mounting cap and arm..
And good old elbow grease and a soft wire brush, I managed to clean them up to this.
I,m not going to open the steering unit, as i know it was in good mechanical order before the resto.
I cant seem to source some balljoint spring washers at all, despite my best efforts.
If someone can point me in the direction of these elusive items, I would be very greatful for the help
Tim
Tim
