orange fastback
col1600
Re: orange fastback
Post by col1600 » 16th February 2015 - 11:25pm
Thanks broady, im getting there "eventually"
that was a good while ago that i had a go at electrolysis, and im telling you .....that s@#t really works.
i found it really affective, what i did was youtube the arse out of it and gather up the info on the do's and donts.
there is a shed load of info on it, all pretty similar at the end of it.
what you will notice is, is that most people use a 12v car battery charger to connect up to the electrodes and the piece that there treating but i found this waaaaay to slow progress.the reaction was very slow and only small bubbles were seen. so i substituted the battery charger for a welder instead, this gave instant results, but the basic set up consists of a bucket or container (not metal!!) place lengths or metal rod/rebar in the corners of the container standing upright, secured with cable ties, connect all these bars together, i had a bit of 6mm cable around so used that, fill the container with water and throw in half a box of baking soda, lay a piece of bar/wood across the top of the container (if you use metal rod make sure it doesnt touch the other rods in the corners of the container, suspend a piece of wire from the bar/wood and attach the piece that you want to treat, submerge the piece in the water, now attach your leads from your charger/welder, positive goes to your corner rods that are all connected together and the negative goes to the piece suspended in the water, turn on your power and watch the process begin. the welder worked really well in fact it actually boiled the water, i couldnt wait 10 hours for a piece to complete so the welder route had the job done in half an hour. watch out tho it does give off a gas, hydrogen i think, so no smoking!!. hope this helps a little bit, as i say there is any amount of info on the interweb but give it a go, it works...
the workshop is a bonus, im lucky ill admit, i used to do this sort of think when i was in the uk and all i had was a single garage with an up an over door but i managed some how. space is a something were not short of over here so no point in building a rabbit hutch.
You Love It.!!!
col1600
Re: orange fastback
Post by col1600 » 17th February 2015 - 12:28am
ok so i know i offended some people way back when i cut out the fresh air vents in the front panel
so i hope this goes some way to keeping them people happy..
You Love It.!!!
col1600
Re: orange fastback
Post by col1600 » 20th February 2015 - 1:57pm
well did anyone rumble me on the "new" air vents!!
i thought id have to come to a compromise when i cut them out as i didnt wont anymore water problems, so instead i airbrushed imitation vents back on the panel to give the illusion..
You Love It.!!!
Marko
Re: orange fastback
Post by Marko » 20th February 2015 - 4:59pm
that's very clever and had me fooled for sure!
viewtopic.php?f=4&t=6896
col1600
Re: orange fastback
Post by col1600 » 20th February 2015 - 5:03pm
cheers mark....thought it might be a novel idea, havent seen it done before so thought....why not.
You Love It.!!!
In2Rust
Re: orange fastback
Post by In2Rust » 20th February 2015 - 5:10pm
Nice vents looking good 8)
1969 Peru Green Squareback
Chino
Re: orange fastback
Post by Chino » 20th February 2015 - 7:08pm
Loving that idea, nicely done :)
col1600
Re: orange fastback
Post by col1600 » 21st February 2015 - 3:00pm
here are a few more pictures with the body off
its always a good day when the body is put back on. thanks to a few mates a bit of muscle and an overseer it went straight back on with out a hitch....
You Love It.!!!
jmarkha1
Re: orange fastback
Post by jmarkha1 » 21st February 2015 - 6:26pm
looking great and a real milestone getting it back on the pan - keep going...
Re: orange fastback
Post by Editor » 22nd February 2015 - 10:42pm
I'm going to have to see those airbrushed vents for myself before I believe you - maybe the whole car is airbrushed, it looks so perfect. ;-)
Cracking job, Gromit!
col1600
Re: orange fastback
Post by col1600 » 23rd February 2015 - 1:41pm
cheers for comments chaps. dave its turning out nicely not perfect by any means. i guess its all down to budget.
ive seen equally good type 3's last year at bugjam (beige notchback). a lovely unwelded example with brand new stainless bumpers allround , now thats my idea of getting pretty close to perfect.
You Love It.!!!
col1600
Re: orange fastback
Post by col1600 » 24th February 2015 - 7:28pm
some work i done on the clocks and dash.
so we all know that your not likely to get arc eye from the lights in the dashboard cluster, so i upgraded them using low wattage L.E.D's
the sort that come on a roll have a self adhesive backing and operate on 12v.
i striped all the clocks down and ran a ring of led's around the inside of each clock, sprayed up the bezels in silver and of course painted the needles in red..seeings as theres a red theme going on..
heres what it looks like lit up.
after the wiring was routed through the original lamp entry hole
i hot glued the hole and and the end of the led row just to make it extra secure, aswell as that the wires can not be pulled from inside the clock
this is them wired up on the kitchen table using a 12v lipo battery
the dash had some bad splits in it, it was really showing its age
i grooved out the cracks enough to allow for a good adhesion when i put the 2 part plastic filler in.
i have used a load of different fillers and glues but NONE come close to this stuff when it comes to smell
this stuff is nasty!!!
after i let it set i wasnt happy with the finish, a small flex of the dash showed a hair line crack in the repair so i was pretty sure it would show up in the paint..
the only way i could see fit to cure this was to cover the complete affected area with fibreglass and fill it.
but this took the original ripple effect away and left it with a flat surface.
so to put it back (and this is very untested and unorthodox but had to try it)
i sprayed the dash with a plastic 1k clear primer, then layed a light coat of aerosol stonechip over it..
i got to say the effect is very convincing,
time will tell how well this fairs out
heres the dash painted up (thanks again for the paint link mark)
the clocks light up nice.
its very subtle and they still dim with the light switch variable pot..
You Love It.!!!
Re: orange fastback
Post by Editor » 24th February 2015 - 11:26pm
Impressive! With the lower current, the dimmer switch should last even longer too (though it probably suffers more from friction-related wear than heat-related).
I remember my son Steve used to do a blue-light mod for Club-Polo members.
col1600
Re: orange fastback
Post by col1600 » 2nd May 2015 - 3:17pm
hi chaps
its been a while again since ive uploaded an update again, but ive been plugging away. As the deadline nears faster and faster!!
ive got a good bit done...
i started with some of the wiring, re-routing the harness back around the car, making off a lot of new connections, cutting back hardened wire ends, soldering and heat shrinking and new wire connections, and replaced most of the harness outer sleeving. i couldnt bend any of the harness around the engine bay or under the bonnet without the outer sleeving cracking on me even though most of the inner wiring was sound..
here you can see the outer sleeving cracking
this part was rigid and started to snap on me aswell
so stripped off the sleeving
new heatshrink
new heatshrink installed aswell as runnig in some new earths
thought this was very interesting!!
found this on the top side of the steering column on the casing around the ignition barrel??
A Load of small item that needed some T.L.C
this will need sound proofing after laying on a top coat of paint..
You Love It.!!!
bigbadbadge
Re: orange fastback
Post by bigbadbadge » 2nd May 2015 - 4:08pm
Wow fantastic work, looking very nice. Like your dashtop and gauges too. I have had a go at mine dash to and used crinkle paint but not happy with it, like the idea of the stone chip, that has turned out really well.
Keep up the good work
All the best
Chris
Chino
Re: orange fastback
Post by Chino » 2nd May 2015 - 5:24pm
Great work as usual Col, look forward to seeing you at Bugjam :)
col1600
Re: orange fastback
Post by col1600 » 2nd May 2015 - 6:25pm
thanks guys
ive got a lot more to show yet...
I started on the engine. its a job ive been waiting to tear into for a while put didn't want to make a start on it until I was ready to start and finish it, i hadn't made my mind up when i started the tear down as to how far I was going to go with it. it was never going to be a big cc engine just a stocker..
the engine seems to be in good shape, i only had it running for a very short time when i got the car, before i started the car tear down, but from that short time all seemed OK. the mileage reads 63 thou and all the mot papers seem to back this up. there was a small drip of oil over night but seemed to coming from the crankshaft oil seal, which was going to be replaced anyway, even though it doesn't come with the full engine gasket set!!
so the lump was the usual oilly rusty looking engine (cant find the pictures!! but you know what i mean)..
let the tear down begin..
ok sorry but photobucket is doing my head in it keeps freezing up so ill update later...
You Love It.!!!
col1600
Re: orange fastback
Post by col1600 » 2nd May 2015 - 7:52pm
im signed up to flickr now so ill try again..
i ended up splitting the cases. then washed an degreased washed again degreased again....
i grabbed a large garden bin (clean of course). filled it with hot soapy water, ran the compressor up and stuck the air line in to the water to agitate it all around the engine cases.
once clean i ended up de-burring as much of the rough castings as i could, with sandpaper on large areas and a dremil and small file for the tight spots. after the cases were clean and degreased for the last time, i sprayed them with an engine enamel paint which dries to a sheen finish. also sandblasted as many engine parts as possible (not the cases though).
the heat exchangers were in good shape,
one of them did require a tiny patch welded on put other than that in good condition, i sandblasted both of them and afterwards finished them with very high temp paint, the paint needs to dry but will only cure properly with heat so i sparked up the bbq to heat treat some parts. (misses wouldnt let me use the oven!! shes funny like that.)
You Love It.!!!
Re: orange fastback
Post by Editor » 5th May 2015 - 2:07am
Impressive stuff, and your heat exchangers are better than many, particularly the exhaust pipe itself, which can rust through and leak into the heating system. The outer shrouds don't get all that hot - its the fins and pipes with exhaust gases running through that get hot, but it's worth getting a decent coating of paint on the shrouding to hold the rust at bay.
col1600
Re: orange fastback
Post by col1600 » 5th May 2015 - 11:23am
Thanks dave...
A bit of head work..
the valve guides had more play than id liked especially the exhaust ones, so ordered up new ones and new valves.
i blasted the heads clean which came up nice ,then treated them to the same high temp heat paint as before, this time in silver
i found the easiest way to remove the guides was to open them out slightly with a clearance drill to suit a 10mm tap (think it was 10)
then screw in a 10mm bolt to cap off the end, and then from the other side use my hammer drill on hammer only setting and with a masonry bit vibrate them straight out, worked a charm..to install the new guides i found an allen head bolt which fitted in the guides snugly with no wiggle room so not to score the guides bore, and again used the drill on hammer to drive them in nice and easy, i also put the guides in the freezer well before putting them in. new valves were lapped in using a coarse then fine paste, and the head put back together.
i wasnt happy with a few of the head studs
few of them looked like they wouldnt hold up to much so ordered up new ones and replaced
the ropey looking ones..
You Love It.!!!
Re: orange fastback
Post by Editor » 5th May 2015 - 1:00pm
Excessive valve rock due to guide wear is the main reason for valve heads 'dropping', which wrecks the engine, so very wise to sort those out.
In many cases cracks between valve seats and spark-plug holes mean a new head anyway.
That looks an effective way to do the job.
Are the lines around the inner end of the guide anything worrying, or just in the casting? (looks like the inlet valve).
Did you have to ream the guides after inserting them? Do you need to skim the sealing surfaces in the combustion chambers for the barrels?
I have this to look forward to on mine, and I'm wondering if my competence and skills are up to it.
Interesting to see the Trades Description Act note. Going to Stonor last year, I was checking the Variant speedo against the GPS, and it was spot-on, unlike the Mk5 Golf which reads almost 10% over, and the Mk3 Golf which is about 5% optimistic. Maybe you can sue the manufacturers if you get a ticket for exceeding the speed limit, so they've made them over-read.
col1600
Re: orange fastback
Post by col1600 » 5th May 2015 - 11:41pm
Dave i examimed the heads and all seemed fine so i pretty sure i would have noticed any cracks. I can see what you mean from the picture but its only casting marks. When i blasted the heads i was really carefull around the combustion area, and made an effort not to hit that area full on, i turned down the pressure really low, the media im using is ultra fine crushed glass, and can be used delicately when needed,
i didnt ream out the guides as the valve fit was very good. No sticking points and a piston like feeling to them. (That makes sence in my head). Im by no means a vw master mechanic, and theres plenty others out there that would have a lot more experience, but i feel competent enough to tackle the oily bits. i found a great information source on you tube. The guy is called "vwdarrin" and has some great videos, i found if i had a question in my head, i would find the answer in one of his videos.
You Love It.!!!
col1600
Re: orange fastback
Post by col1600 » 7th May 2015 - 8:53am
You Love It.!!!
Re: orange fastback
Post by Editor » 7th May 2015 - 11:53pm
Lovely job - something to be really proud of.
Did you source a replacement foam pad for the top of the oil cooler? That's quite important as it directs the cooling airflow through the oil-cooler vanes. If it's not there, much of the air flows over the top between the cooler and engine tin, and can be a problem in hot weather or when the engine is working hard.
col1600
Re: orange fastback
Post by col1600 » 8th May 2015 - 7:33am
thanks again dave...
yes i replaced the foam pad. i used a grey scotch brite pad and cut it to size (the type used for scuffing back paint work).it takes up the void that the foam pad did and im thinking it wont perish and fall apart like the foam does..
You Love It.!!!
