Front Bump Stop rotted out
- Stuart Sepple
Any tips for repairing it on a Late Type 3? Will prob. have to find someone else to do it as too busy at moment to even clean the poor thing!
- aircoolsteve
Re: Front Bump Stop rotted out
hi stuart. has the knob that holds the rubber bung rotted off, or is the rot a bit more extensive? a pic would be a good idea of that area. i've repaired quite a few of these as they are in the firing line of all the moisture. if you can find a dead beam you could saw the truntion off it and weld it onto yours. if its just the button bit i can make that easy enough. i'm in chatham so not that far from you.
steve
steve
- Stuart Sepple
Hi Steve,
will get a photo at the weekend. I have some new Rubbers I picked up a while ago, in the garage, that I think, are attached to truntion sections, will check those out as well
- Stuart Sepple
Steve,
some pics
Stuart
some pics
Stuart
- aircoolsteve
hi stuart. well that doesn't look all that bad from here. if the beam is in sound condition then just replace the buttons that hold the rubber bit.
don't know where in s london you are but i'm in chatham. i could do it if you like. let me know.
steve
steve
- Stuart Sepple
I'm in Charlton - crazy mad at work at the moment but will let you know when I have a moment to think
- Stuart Sepple
Hi Steve,
do you fancy fixing the button? Will need to organize it if your OK to do it
Stuart
Stuart
- aircoolsteve
hi stuart. i'll make a set up and get back to you as soon as i'm ready. how many are missing?
steve
steve
- Stuart Sepple
Just one, the lower one on the passenger side, the others look fine to me. Approx. how much do you charge?
Stuart
Stuart
