Master cylinder
Master cylinder
Long running saga trying to get 68 fastback on the road. Master cylinder decided to pack up can you buy replacement or is there a equivalent on the market many thanks
Re: Master cylinder
I don't know specifically for type 3, but for type 4 a company called Pastparts reconditions them
Others with better type 3 knowledge will be along soon
Re: Master cylinder
Pastparts won't be of any help to a type 3.
Just buy one from any of the usual suppliers Adie..M7 gets my vote. It'll probably be for a left hooker so You may have to make new front solid brake lines
Re: Master cylinder
used passports for my type 4 master cylinder, this year it was leaking at the truneons fillers on the top some T1 from just campers has done the trick fit better than the ones that were used in the up grade.
What did you get sorted Adiebriz new master. or ...
