steering wheel catching on indicator stalk
Why is this happening. It's from a type 1 but it's the correct wheel for the car. Or is there a subtle difference somewhere I'm missing?
Re: steering wheel catching on indicator stalk
i think were going to see a photo of this one. Which bit of the stalk on which bit of the wheel?
I'll take a pic and try to upload. tried to do it earlier but the image doesn't load.
Are you following the steps I posted? Which image site have you joined?
yes, flickr. Followed exctly. Perhaps it didn't load in preview?
Paste the link to the flicks image on here and ill see if it works
Edit: Ive had a look at your thread and figured out the picture, you should be all set now!
Ok, so it seem that the car originally came with a plastic large wheel as the indicator stalks and wiper stalks are on the column. This is blocking the wheel from turning with the old style d-ring steering wheel. My option appears to be plastic ugly wheel or aftermarket wheel. That is very disappointing.
considered changing the column to original?
i hear you.
it was a loaded question tbh - I have a complete steering column from my early 70 car that was fitted with a D ring wheel
If and when let me know and am sure we could figure something sensible if you wanted to go that route...
I assume this wasnt done well then? the later type 3s had wipers on the stalk and it wasnt a bit job to put the late parts on an early car with out issue.
