Electric fuel pump position.
Post by sparkywig » 19th May 2018 - 8:58pm
Anybody fitted an aftermarket fuel pump under the tank, and can post/send me some pics please?
Kai
Re: Electric fuel pump position.
Post by Kai » 20th May 2018 - 9:01pm
If your asking me? Depends on what you are after?
The set up I’ve gone for...... FI tank wth internal swirl pot, 12mm ID outlet from the tank gravity feeding a Bosch 044 pump with an 8mm outlet to the fuel rail.
Pump was originally mounted to the top bar of the front beam using welded brackets. But is unique now. Not the best position as I fear it gets hot from hot air drawn from the radiator.
However, originally in my carb days, I had a fasset fuel pump screwed to the top part of the beam. 8mm inlet and outlet I believe with a switch 12v live. Its a good idea to develop the mounting in an effort to reduce the fuel pump noise. Perhaps rear mounting it or go the whole hog and develop an internal pump set up.
Post by broady_6 » 20th May 2018 - 9:33pm
A friend of mine has one on a beetle, I can ask him for some photos if its useful?
Post by sparkywig » 20th May 2018 - 11:19pm
I've got the rotary pump in the pic, and was looking for suggestions on how to mount it in the restricted space under the tank.
Post by broady_6 » 21st May 2018 - 7:47am
Yeah hes got it mounted under the tank on the bulk head so I could ask him for photos?
Post by broady_6 » 22nd May 2018 - 8:11am
