1971 Fastback KBY 217K winter 2016 tidy up
muddy
Re: 1971 Fastback KBY 217K winter 2016 tidy up
Post by muddy » 11th November 2017 - 7:54pm
Some good news soon arrived, my Porsche Teledials came back from the painters. Fully dipped and stripped, fully powder coated silver then the centre painted bright red and then finished off with lacquer.
Very happy with them. Looking forward to seeing them when the car is on the ground off the axle stands.
Instagram: @type3.fastback
muddy
Post by muddy » 11th November 2017 - 8:00pm
It has taken every night this week to fit the wings. The beading has been a swine. Help again from the wifey and they are all now on, with exception to a couple of bolts.
Whilst the lights and bumpers are not fitted yet I've taken the opportunity to machine polish all the wings as I fitted them. I also polished up some of the newly painted bits and the front and rear valances. All came up pretty well, so everything is nice and shiny. The body will need a re-spray at some point as the original beading cracked and pulled a lot of the paint off which hasn't been hidden by the new beading. That will be phase 2 in a year or 2.
Plus I don't like the black beading and would like white like the original stuff that came off.
Also got some wheels spacers on order and got them fitted.
muddy
Post by muddy » 11th November 2017 - 8:03pm
Absolutely gutted today as we started the engine for the first time and the oil cooler p£££$d oil everywhere.
On a positive note, the engine did start. It'll need the timing setting but all good.
Managed to strip out the tinware in situ and I'm trying to figure out how to fix this.
Back to square one. Pretty dejected tonight.
kaddy
Post by kaddy » 11th November 2017 - 9:28pm
In the scheme of things considering what you have accomplished so far, its a minor glitch.
You have a class car there, well done.
Post by broady_6 » 19th November 2017 - 7:15pm
Wow this has come one quickly! I bet it hasnt felt it for you but thats very slick looking and well together sir!
German Essex Girl
Post by German Essex Girl » 1st December 2017 - 11:19pm
OMG I am SO pleased to see KBY217K in such great order! This was our much loved family car bought new for my Mum when we were kids! We had many happy hours in this car. I would clean her every Saturday to earn my pocket money! I know this car so well and my older sister had it and kept it going for many many years. So pleased! What an amazing job you have done! Please keep me posted
kaddy
Post by kaddy » 2nd December 2017 - 1:14am
Last post is magic , it doesn,t get any better for a fasty restorer... 8)
muddy
Post by muddy » 25th March 2018 - 5:51pm
German Essex Girl,
WOW great to here from the original owner. I still have the original sale receipt too. Hope you approve of what I'm doing with the car.
It's proving a stubborn SOAB though and doesn't seem to want to be put back on the road. Hopefully it won't be long until it is though.
muddy
Post by muddy » 25th March 2018 - 5:55pm
Ok, so after some set backs with various things. Particularly the brake fluid leak from the master cylinder, I decided in my wisdom to spend even more money on the car.
So I've bought an ISP tachymeter from Fabrik Mike, a second battery and voltage sensing split charge kit and an Air ride performance V2 kit with Monroe air shocks for the front. Oh and a 12V gauge to keep an eye on things.
Air ride is to enable me to get up the drive as it is a little steep and doesn't like lowered cars.
The split charge system is to help with the air ride and compressor and also to provide power to a future amp for a stereo that I hope to fit in a year or so.
muddy
Post by muddy » 25th March 2018 - 5:59pm
So, first off a few weeks when there was a day that was above freezing I fitted the Tachometer. First I removed the non functioning clock, which was easy enough.
I then ran 2 new wires to the coil. Didn't take long to do.
Engine started and it worked a treat, does a nice full sweep on start up.
ImageIMG_4331 by Craig Mudd, on Flickr
muddy
Post by muddy » 25th March 2018 - 6:02pm
Next I bough and fitted a second battery and then fitted a Durite volt sensing relay which turns on at 13.3V and off at 12.65V.
ImageIMG_4329 by Craig Mudd, on Flickr
ImageIMG_4332 by Craig Mudd, on Flickr
muddy
Post by muddy » 25th March 2018 - 6:07pm
A bit of forward thinking and the idea that I'd like to put a decent stereo system in at some point. I have a lot of high end cables from previous show cars and a Hertz HP5 amp to fit, might as well put them to some use.
I ran a load of audison RCA cables from front to back, plus added a few spare wires too for amp switch on etc. Don't want to be pulling the carpet up to many times when it finally gets fitted.
ImageIMG_4333 by Craig Mudd, on Flickr
ImageIMG_4334 by Craig Mudd, on Flickr
ImageIMG_4335 by Craig Mudd, on Flickr
muddy
Post by muddy » 25th March 2018 - 6:14pm
Last job I've done is run the air performance V2 air ride loom through the bulkhead and connected it up to the battery.
I also temporarily fitted the ECU manifold , tank and compressor and tested that it all worked ok.
Test run was good, all be it the thing leaked like a sieve as I hadn't fully tightened or seal the connections.
All good though, fingers crossed it'll work again when it's fully fitted.
Only down side to the test fit is that the air shock height seemed longer than the normal shock that came off and in doing so raised the car by about 25mm, so I'm going to have to re-fit the original dropped spindles and take off the standard spindles and will probably have to take the beam from the low position to high to get the ride height I need.
ImageIMG_4338 by Craig Mudd, on Flickr
Post by broady_6 » 27th March 2018 - 9:57pm
Liking the twin battery idea! Had always wondered about it for when im camping. Run my inverter off the spare without hurting the main one, still might do it but I recently bought this
https://www.ebay.co.uk/itm/50800mAh-Car ... 2749.l2648
It fits in my pocket and it cant actually crank a stock engine over. Not fast enough to start it. But if it was just a weak battery then it would certainly make the difference so im temped to live dangerously and rely on that booster pack. I really am very impressed with it.
Also
, on Flickr
Im not at all jealous :puke: and dont hate you or anything! I very much wouldnt mind one of these when the cars done
muddy
Post by muddy » 30th April 2018 - 8:42pm
After getting over the disappointment of my failed brakes. I've picked myself up and hopefully focused to get the car on the road, albeit 6 months later than planned.
So I've removed the CSP master cylinder and returned it back for invesitgation. In the mean time I've ordered a new one and am waiting on it it's imminent delivery.
ImageIMG_4401 by Craig Mudd, on Flickr
Over the last few weeks I've been trying to sort my front air ride suspension. It seems that when I fitted the Monroe airmax shocks to the standard spindles and with the beam at it's lowest setting, the compressed length of the shocks actually increased the ride height :evil: :crybaby:
Fortunately I actually bought the car with drop spindles fitted, and during the restoration opted to put standard spindles back on. So all i needed to do was dig them out, clean and paint them up and fit them.
Unfortunately removing the discs of the standard spindles meant I damaged the inner bearing on both sides trying to get it off the spindle. :evil: :crybaby: So I had to buy x2 new inner bearings.
And also as there is a bump stop adaptors fitted, it meant that my ball joint splitter wouldn't fit :evil: :crybaby: so I had to wack them off with a ball joint splitter fork. x2 split tie rod botos later they are off. So I now have to replace the brand new boots for brand new boots. :crybaby:
New inner bearing fitted, boots fitted and newly painted dropped spindles fitted.
ImageIMG_4399 by Craig Mudd, on Flickr
ImageIMG_4400 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th April 2018 - 8:45pm
Compressor, tank and air ride performance fitted to some 12mm ply cut to shape. Hopefully, going to try and get my hands on some german square weave carpet to try and fit on top.
How easy/hard is it to hand stitch cloth edge to carpet?
ImageIMG_4409 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th April 2018 - 8:53pm
Having fitted the dropped spindles, I noticed that there was only a 20mm difference in height between fully deflated and fully inflated. :crybaby: :evil:
I was certainly hoping for a larger lower/raise height than that.
I popped a jack underneath the lower arm and managed only 20mm movement in the arm. So having spent a fortune on the air ride, it would appear that the narrowed adjustable beam I have fitted isn't up to the job for air ride.
A quick messenger chat with the guy in Germany who's been helping me with the air ride, suggested to remove the aluminium block on the sway-a-way adjusters.
After studying the adjusters, I decided to cut out the lower nut and reverse it so that the adjuster had more travel down.
ImageIMG_4423 by Craig Mudd, on Flickr
So I took the plunge, with the beam in-situ and cut and welded them back in.
ImageIMG_4424 by Craig Mudd, on Flickr
I've cleaned it up and then had to repaint the beam. All nice and clean again :D
ImageIMG_4426 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th April 2018 - 8:58pm
By doing this I've gained a further 30mm drop.
The shocks normal compressed length is 9.5", as the beam is at it's lowest I can only get the shock to compress to 11.5". Fully extended 14".
I'm happy with it at the moment, I'm hoping it raises high enough to get up and down my drive. Maybe at some point when I can upgrade the beam to get the car slammed on the floor.
Fully extended
ImageIMG_4434 by Craig Mudd, on Flickr
Fully deflated
ImageIMG_4433 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th April 2018 - 9:02pm
This weekend I tackled the lower portions of each wing, as they had had previous repair work on them and had been painted black. They stood out like a sore thumb. And as I am having issues getting the alignment perfect, I thought fixing this would help some.
So masked off, sanded back and re-painted. The paint is slightly off in shade, but I'm not that fussed, it's blended in ok and I've machine polished it and looks fine for now.
ImageIMG_4429 by Craig Mudd, on Flickr
ImageIMG_4430 by Craig Mudd, on Flickr
ImageIMG_4431 by Craig Mudd, on Flickr
ImageIMG_4432 by Craig Mudd, on Flickr
Post by broady_6 » 4th May 2018 - 11:08pm
More top work, glad you got somewhere with the beam! I must say i thought your inflated shot was the lowered shot though haha
muddy
Post by muddy » 30th May 2018 - 5:26pm
So after some wonderful customer service from Machine 7, I got a full refund on the original master cylinder.
Unfortunately when I fitted the new master cylinder, after a bench bleed and all 4 calipers bled, the master cylinder failed by leaking brake fluid out of a vent hole. :crybaby: :crybaby: :crybaby:
After more great communication with Machine 7, we could not get to the bottom of it, and CSP recon the 2nd one has failed internally again.
So they are going to send a 3rd one out for me to try. :retard: :retard: :? :? :( :( :(
muddy
Post by muddy » 30th May 2018 - 5:34pm
So to get over my disappointment, I started to fit my carpet that I got from Fabrik Mike last October. (It was supposed to be fitted then to ready for the car going on the road).
It's German narrow weave ( a bit cheaper than squareweave). It's a little thicker so I assume is slightly more challenging to fit.
I've only decided to fit the side and back pieces for now, as I want to be able to have access to the brake pedal assembly.
With the help of some high temperature compact adhesive, successfully fitted the carpet pieces with no real problem.
ImageIMG_4498 by Craig Mudd, on Flickr
ImageIMG_4502 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th May 2018 - 5:37pm
I was desperate to get the back seat in. so I scrubbed it clean (and the front seats) but wasn't happy with the condition.
They still appeared dirty with the odd stain and were quite faded.
So i bought some black dye (Autobrite Direct) and applied it to the front and back seats.
They turned out fantastic. Look almost brand new.
Not sure if you can see the difference with before and after:
Before:
ImageIMG_4475 by Craig Mudd, on Flickr
and after:
ImageIMG_4480 by Craig Mudd, on Flickr
muddy
Post by muddy » 30th May 2018 - 5:41pm
Bottom part of seat.
Forgot to take a before pic, so this is it after dye applied:
ImageIMG_4479 by Craig Mudd, on Flickr
And this is one of the front seats;
Before:
ImageIMG_4473 by Craig Mudd, on Flickr
After:
ImageIMG_4478 by Craig Mudd, on Flickr
Pretty pleased with the results, really cleans up the interior.
headliners just letting everything down now.
