lowering
gerrygerbil
lowering
Post by gerrygerbil » 11th July 2018 - 11:03pm
i lowered my squareback and now its no suspension its bottomed out on the front . can you give me advise on inner and outer splines
are the outer splines on the arm and do i only need to alter one side off the car to lower . can any one give me a quick run down so i can sort explaining the process thanks g
Re: lowering
Post by broady_6 » 12th July 2018 - 9:11am
Lots of useful info here https://www.thesamba.com/vw/forum/viewt ... p?t=188457
https://www.thesamba.com/vw/forum/viewt ... 65e24c7804
https://www.youtube.com/results?search_ ... ing+type+3
Not sure what your asking. But I assume you mean you have lower the car and now it has no suspension travel at the front. So I assume you have lowered it on to the bump stops. It depends how low you want to go with it but those who want to make it undrivable tend to cut the bump stops off. If you want to raise it back up, just reverse what you did to lower in. In true haynes manual style :D
gerrygerbil
Re: lowering
Post by gerrygerbil » 12th July 2018 - 4:13pm
cheers yes want to have some suspension its non existent right now ,do you only need to adjust one side ie remove the trailing arm and turn two notches think i have moved inner spline and outer up so will have a crack at the weekend to sort thanks broady
Kai
Re: lowering
Post by Kai » 12th July 2018 - 10:14pm
In my experience, with the front you tend to only move the inside spline. You can see where the outer spline attaches inside the lower arm. Obviously for the inside spline it should be held in by a bolt.
The process I recall is too underdo said bolt, pull the arm off along with the torsion bar and move it around to where you want it. Measure the distance between the shock too and bottom bolts to make sure you’ve got it even.
Re: lowering
Post by broady_6 » 12th July 2018 - 10:25pm
The inner spline is 29 teeth and the outer is 31 teeth so there is a nice vernier movement to be had of 5 minutes. So you can adjust it this way, or you can move the outer 1 spline. Which i seem to recall works out at about 1 inch at the end of the trailing arm.
Hope this helps
gerrygerbil
Re: lowering
Post by gerrygerbil » 13th July 2018 - 10:47pm
thanks defo think i moved the inner slpine and then the outer arm will refit and then adjust the inner spline 1 notch see how i get on thanks again lads
Who is online
Users browsing this forum: No registered users and 1 guest
