Late Tailpipe Fittings Type 3
Has anyone found a source of the Parts that would make up a Fitting Kit for the Late Type 3 Tailpipe please i.e. the Clamp and Seal Ring ?
Don’t know how you would describe the size of the Clamp or Seal Ring but the latter must be something like 32mm inside, 40mm outside.
Steve
Steve
Re: Late Tailpipe Fittings Type 3
VWheritage sell them. I bought one earlier this year.
Price will make you take a deep breath. But here it is
https://www.vwheritage.com/311298055a-e ... t-vw-spare
Yes. I know.
That’s why I was asking !
There must be another way ?
Just out of interest, do Members know that VW Heritage do give Club Discount.
It’s only 5% I think but better than nowt !
Think you have to Register your Membership with Heritage. Then if you don’t log in you see full price. Log in and you see discounted price.
Decided not to waste time looking for alternative Tailpipe Clamp and Seal Ring. Just bought a new ( Jopex ? ) late Type 3 Tailpipe & Fitting Kit from VW Heritage yesterday. Already have a new Leistritz Silencer. All insurance for the future of my Variant.
On the Left, Late (Big bore) Tailpipe .. Seal is 43mm internal X 52 mm external
On the Right, Early (2 part) tailpipe.. Seal is 34mm X 43mm
For both tailpipes, the bolt into the silencer end is M8 X around 15mm
Availability: Late: Difficult to find- I've only got half a dozen of them, so I'd have to really like you to let one go!
Early: Common as muck, but if you get stuck, I've got a small quantity & I believe Dave has a quantity too- I've heard Mike say it's the same size as Beetle tailpipe, But in any case, it's the same size as Heat exchr to silencer.
I only said same as Beetle tail pipe as you can buy those kits separately, but yes also the same as the exhaust to HE joint.
Also worth pointing out a late split screen / early bay tail pipe kit has the same clamp and has other parts that are useful to fit the early Type 3 TP.
The strap clamp for the tail pipe to damper pipe in that kit is ever so slightly smaller diameter, but with a longer bolt it can be made to work.
I've seen similar clamps in Halfords some years ago, for downpipe joints, but don't know what sizes are available. I've got lots for the Beetle and Type 3 HEs, plus damper pipe joint, but have run out of the big-bore (don't need them now anyway).
