Casa de Fye's autos...
Re: Casa de Fye's autos...
Blimey, never heard of that before! Sounds painfull too. Best wishes
I will get through this somehow. Just another delay...
I did a thing:
Started to scuff to prep for paint. No going back now.
About half way done sanding...
I hate sanding and filling bodywork.
1967 Karmann ghia
1972 412 variant
ex AA van
4" scale foster traction engine.
vw caddy pickup mk 1
1972 412 variant
ex AA van
Started jamming the car in sealer. Then, after all the sealer is applied, I will sand again.
No more pink or scallops...
Next is blocking and blem repair.
just clear coat it as is.
kool grey colour car.
1967 Karmann ghia
1972 412 variant
ex AA van
1972 412 variant
ex AA van
Sort of will. It will be a pearl clear
The last of the prep is done, the dash is taped and sprayed as well.
I finished jamming the doors, trunks and roll bar. Next spraying will be the roll bar, dash then all the sheetmetal exturnals.
I finalized the color. It should flip from black to blue. This was 4 coats I think I will use 3.
I was going to repair this hood and swap, but the structure is full of holes, crunchy and not sound. So... i will cut the louvers out and move them to the current hood.
The engine cover got more bodywork today. I will have to break out a little bondo for the lower front mount area then more sealer. This car will look sooo much different.
That looks wonderful.
So smooth.
So smooth.
1967 Karmann ghia
1972 412 variant
ex AA van
1972 412 variant
ex AA van
I moved the car a bit more and in the light I found 7 bangs in the NOS trunk lid. So, hammer/dolly and much better! But... then I found one more. Doh!
I'm out of primer for now...
2nd picture shows the flake in the highlight color on the gauge cluster panel. I hope it shows a bit through the pearls...
What have I learned the 3 days of working on this NOS trunk lid? Unless they are stored in a padded box? NOS does not mean pristine, straight metal. However, verses several other lids I have or do own? It is pristine!
I am currently chase more dings. The 1st ones were overshadowing the one I have since found.
Started working on mixing the old hood with the louvres... then I have to cut the hole, flange the insert and body work it...
Been creating a flange on the panel to minimize bodywork on the hood. Next, I have to snadblast the piece to remove some old bondo between some louvres...
On the prior post, you can see how rough the louvre area was. So, today I sandblasted the piece not knowing what I would find.
Pre blast
In process
After blast in raw metal
In primer sealer
I am pleased with the result!
Pre blast
In process
In primer sealer
