Smell of petrol - no sign of leaks
vwblue
Post by vwblue » 31st March 2009 - 12:48pm
Hi, I'm getting a strong smell of petrol in the cabin of my 1970 Fastback. It seems seems to occur when petrol starts sloshing about around corners, but seems to stop when the tank is less than half full.
When I check under the bonnet the smell seems to be coming from the filler neck area.
The tank's fine, the hoses and connections are in good order, and there are no signs of any leaking petrol. The connections and hoses under the tank are fine too.
An ideas?
Thanks,
Ian
Post by Editor » 31st March 2009 - 12:58pm
Along with many others, you've got a split filler vent hose - a J-shaped pipe that fits between the filler neck and the tank vent, with an integral grommet through the inner wing. It pours fuel out on left-hand turns as the fuel sloshes up the filler pipe.
I repaired mine by using a length of 1/2" breather hose with some flexible plastic trunking to stop it collapsing. Some people have managed to fit a copper plumbing elbow on the filler neck and soldering it, but I've not found one that fits over it yet. That allows a straight length of hose to be fitted. there may be other ways. Jim Adney, a guy in the USA sells a kit to replace it all, but as with most things from USA, it costs a fair bit more to get it sent over.
You can get repro ones - they tend to be expensive, and some don't actually resist attack from the petrol! Typ3Konny has one that's OK for the filler necks with screw in rather than bayonet caps. Yours is likely to have the bayonet type cap.
Post by purplepeter » 31st March 2009 - 1:23pm
It looks like this!(yours is the one on the right)
vwblue
Post by vwblue » 31st March 2009 - 5:28pm
Thanks both very much for the info.
I've just checked this hose (under front wing) and it looks like someone's replaced it with a piece of braided fuel hose. There's no sign of any leakage but it must be totally blocked as it's twisted and has a bad kink in it, which must be the problem. The hose used is clearly not up to the job!
Thanks again, I'll see what I can do about replacing it.
Cheers,
Ian
Post by purplepeter » 1st June 2009 - 10:00pm
A bit of an update for those interested..I've obtained a pair of these pipes,311201179A & 311201179C (early & late),and ascertained that the only difference between them is that the earlier one is approx 10 mm longer!
I spoke to Simon Kelley at stonor yesterday,& have lent him the earlier pipe as reference,from which to make a mould,& it looks like he'll be reproducing them in the not too distant future!
Obviously,as we all know with Simon,it'll be a good quality part,at a very reasonable price!
Watch this space!
69cider
pipe
Post by 69cider » 3rd August 2009 - 6:18pm
wheres the switch over point from early to late?
cheers
jamie
Post by purplepeter » 3rd August 2009 - 6:21pm
in the case of the vent hose its around '71 ish,but makes no difference as both hoses are identical except the later one is 5mm shorter
Post by Editor » 5th August 2009 - 1:07pm
I believe it's when they put in the screw filler cap. If you have the bayonet sort, it's the earlier one, screw cap is the later version. (Hope I don't look an idiot over this!)
cbst3
Post by cbst3 » 8th August 2009 - 8:52pm
I too have this issue - I can see that petrol is coming out of this pipe and has taken off the underseal in a line down the inner wing.
Firstly, does the wing need to come off to get to this pipe? I was going to take the wing off at some point anyway to give it all a good clean behind, so if I can fix the pipe at the same time it would be ideal.
Is there any progress on the repro part for this? I would be interested in some kind of repair/replacement kit if available
If not, any ideas and if possible, pictures, would be appreciated as to how I can sort this out.
Thanks.
Colin
Post by purplepeter » 8th August 2009 - 10:14pm
Its easily accessed if You just take the front wheel off!
I think theres an item in the club technical manual,but theres lots of ways to bodge it up-I used normal fuel hose of the right Diameter,Dave Hall advocates the addition of spiral binding to prevent the hose from kinking,or you can solder on a copper elbow & eliminate the 90 degree bend
re progress on the new part-i think its too soon to start nagging simon-reverse engineering does take a while,& its only been 2 months-i'd anticipate hopefully having news by the AGM in october!
Post by Editor » 9th August 2009 - 12:51am
It's certainly easier to do the job with the wing off, but not essential.
When the wing's off, make sure you clean off any corrosion from the filler pipe where it sits against the mounting bracket, and apply lots of Waxoyl or something - that's a mud trap and can rust through the pipe.
Post by purplepeter » 27th November 2009 - 6:06pm
Time for an update chaps..Simon now has 311 201 179B available :D
kyle
Post by kyle » 28th November 2009 - 1:02am
wat 1 of them? :?
67 fastback
65 bug
KNOWLEDGE IS POWER!!
Post by Editor » 28th November 2009 - 1:59pm
He deals with (owns?) a rubber factory in the Far East so he probably has quite a few!
Post by purplepeter » 29th November 2009 - 1:09pm
Yes,obviously!
This is now a source of new filler vent pipes,in pretty much endless quantities
You can contact Simon via ebay,where his user name is "notch1500" or PM me for his email address
Here's one of simons
