412 1700 F.injection throttle body hose
- Stevosquare
Hi
Does anybody know where I can get the hose/pipe that runs from the throttle body as pictured.
Mine is all taped up. Are they the same as a type 2 or is a type 4 specific part?
Many thanks
Steve
Many thanks
Steve
- Attachments
- BB0E3188-4F2A-41BF-ABA6-E2874FD1E1EA.jpeg (172.89 KiB) Viewed 9252 times
1973 S.A 412 LE Variant red.
1972 U.S Karmann Ghia Coupé (Type 14)
1972 S.A 412 LE Variant Blue.
Re: 412 1700 F.injection throttle body hose
Hmm, I think that's a type 4 exclusive part.
Type 2 did not use D-Jetronic
This page has some useful links for parts from other cars http://www.vwtype3and4club.org.uk/partswap.php
You might want to download the D-jet manuals w107.pbworks.com/f/DJetronic.pdf
and www.412club.nl/BOSCH%20D.pdf
Put a wanted ad up, someone may have one, or you can try Volksfarmers
- Stevosquare
Thanks for that info. I’ll take a look.
If I can’t get one I’ll try and repair the existing one.
I'm a bit rusty on D-Jet (about 35 years and haven't looked closely at my 412 saloon)...... but I don't actually recognise that engine bay and that metal box just before the rubber pipe to the throttle valve looks like an air flow metering flap, which I think is an L-Jet component.
L-Jet was used in the final years of the 412 in the US, maybe SA too, if so you will struggle to get components in Europe ?? Beetles and type 2's also used it over there I believe
- Stevosquare
Thanks.
That’s not my actual engine bay. The VW specialist called me today and told me the hose was a bit worse for wear.
Mine is a SA import so I’ll go and have a look tomorrow.
Thanks again.
Thanks again.
Ah, so that's why I saw a very similar picture on a google searchStevosquare wrote: ↑14th August 2019 - 9:50pmThat’s not my actual engine bay. The VW specialist called me today and told me the hose was a bit worse for wear.
Best put a real picture up of yours then
- Stevosquare
Went to see my car in the garage today.
Here’s the hose covered in tape. Wrong air filter element in there too.
- Attachments
- C64885F0-CCCC-4ED3-911D-75251813F536.png (820.49 KiB) Viewed 9223 times
Connecting hose for intake runners is 022 133 241B dims are 35mm bore x 4mm thick x 58mm long (from parts book). So you know what you're looking for, but I don't know where to find it!
