Column mounted wiper switch
Post by kaddy » 28th May 2025 - 9:47pm
I cant seem to get a supplier for a new wiper control switch. My own is a hi/lo switch that is only working on high. I suspect the low speed contacts are worn. Has any one had any success in repairing the worn contacts with solder. Thanks.
Re: Column mounted wiper switch
Post by broady_6 » 29th May 2025 - 2:11pm
Not in a position to check, but is it a type 3 part number? My car has the dash mounted rather than stalk, so I'm not familiar. But beetle ones are readily available. Maybe you could modify one of those?
Post by purplepeter » 29th May 2025 - 7:53pm
Is there a number on the back of the stalk? ie facing the windscreen
Post by kaddy » 29th May 2025 - 11:57pm
I am not sure of the number but will check tomorrow. Its for 2 speed wiper , and a pneumatic washer connected to the spare
Post by broady_6 » 30th May 2025 - 7:17am
Its a Type 1 part 111 953 519E , Theyre readily available.
https://www.heritagepartscentre.com/uk/ ... witch.html
Post by kaddy » 30th May 2025 - 9:33am
Thanks, but your link connects to part number 111-953-519/GR which may or not be different from your reference of 111 953 519 E, I dont know. And i see no mention of its suitability for a Type 3. I have contacted heritage to see if its suitable. Thanks.
Post by broady_6 » 30th May 2025 - 12:16pm
The difference will be the markings on the stalk or similar.
Post by kaddy » 30th May 2025 - 12:20pm
Heritage say their 111-953-519/GR is suitable for a 2 speed motor. Just waiting for them to confirm Type 3 's are a compatible vehicle.
Post by kaddy » 30th May 2025 - 12:24pm
I'm off out now to confirm what markings is on my original VW one,,
Post by kaddy » 30th May 2025 - 2:34pm
Heritage have just contacted me with the part number 111-953-519/HAC that they maintain is the correct part i need, plus a new kidney dues to the cost....aarrrggh.
https://www.heritagepartscentre.com/uk/ ... unted.html
Post by kaddy » 30th May 2025 - 2:49pm
Wiper switch off and it seems to be a SWF wiper switch brand with no part number visible at all. I have seen SWF wiper switches on Autodoc so it may be a cheaper alternative to VW. Plus they seem well constructed too and fairly robust. Ill check it out
Post by kaddy » 30th May 2025 - 3:21pm
I am reliably informed that SWF is the original equipment supplier for the switch for my type 3
Post by broady_6 » 30th May 2025 - 9:54pm
Excellent investigation work that man!
Post by kaddy » 31st May 2025 - 5:57pm
"Bow,Bow" thankyou.
And due to the exorbitant cost, I am going down the 2 speed dash mounted switch route like the earlier typ 3's. Rotary 3 speed switch allows.
1. Low speed
2. High speed.
3. Electric washer.
But leaving the existing non working stalk for aesthetics
s.unsworth
Post by s.unsworth » 1st June 2025 - 12:48pm
According to Dave Halls ( I think ? )
https://vwtype3and4club.org.uk/partswap.php
Wash/wipe switch and valve 8/71>; use T1 8/71>12/73 8/71>; use T1 same year
Does this not fit ?
https://www.ebay.co.uk/itm/276042213399 ... R5aghLXlZQ
Post by kaddy » 1st June 2025 - 2:38pm
According to justkampers its not on their compatibility list for type 3's. Which means no guarantee if i have a problem
Post by broady_6 » 1st June 2025 - 7:33pm
Distance Selling regulations means that if you change youre mind withing 14 days you are able to return it for a refund.
Post by kaddy » 2nd June 2025 - 9:25am
Justkampers dont list it as compatible, so returning hassle is too much. I been there before, lost parts, lost money ect. Mind is made up now going to replace with a dash mounted 3 point rotary switch.
s.unsworth
Post by s.unsworth » 2nd June 2025 - 1:40pm
Why Electric Washers ? Stick with Original Air Operated.
Post by kaddy » 2nd June 2025 - 4:12pm
Because my existing wiper/wash switch does not work correctly. The correct replacement is too expensive, and along with irish customs and duties, its mega expensive. So converting to electric/2 speed is the least expensive and i get to keep my kidneys.
Post by broady_6 » 2nd June 2025 - 8:58pm
You can modify the dash mounted switch to make it electric wash as well. I did it with mine.
Scroll up from here https://www.vwtype3and4club.org.uk/foru ... 500#p66954
Post by kaddy » 3rd June 2025 - 7:27am
Thats the plan broady.
Post by purplepeter » 3rd June 2025 - 9:26am
The compatabilty list that We have is very reliable- it was compiled back in the day by Dave & others, from parts catalogues and physical visits to auto factors, as well as trial and error on the actual cars
Jk , Heritage etc are only in it these days to make money & their staff arent always as acknowledgable as you'd hope
So, at £40 for that part, I'd say its a no-brainer
Its worth a little effort to check with Irish Customs, what the threshold for paying import duties from UK is?- In UK, importing from EU, the threshold is £135, which is how I'm able to buy most of the parts I need from Germany & france- as long as I keep it under £135, I don't have to pay Duty, & VAT in EU is the same as UK, Maybe theres a reciprocal arrangement from UK to Eire?
If Your Son were willing to bring a Tank home for you, I'd rather just give you this FI one I've got, rather than see you pay £125 for that one which looks knackered before you start- It's RHD, FI & of no use to me without modification, but I'm not posting it, so Your son would need a day trip to Bath
Post by kaddy » 3rd June 2025 - 10:05am
I would not have any interest in the tank that was suggested to me as it looks worse than my own. Its a rusty item thats only waiting to leak. As for the £40 wiper switch, thats ok, but when you start totting up vat, duties, ect If its not the correct one, then i am into losing money straight away, thats why i am keen to get the correct part numbered one at the start. I have no reason to doubt Daves lists, and a part number would have clarified a lot for me , but there isn't one.
Irish customs have a tendency to demand a figure for items, you pay, and dispute any charges after in the hope of getting a refund. Its not as simple as people may think. There is no set tarriffs on items like you would expect, its all abit hit and miss. Thats why alot of vw parts business that took place pre brexit, has now reduced significantly. The lack of a proper irish system of customs has a lot to answer for.
Post by kaddy » 3rd June 2025 - 3:23pm
If i go ahead on converting to a dash mounted switch, is this going to affect the park function of the wipers.Thanks fellas.
