Hi,Has anyone got a parts book?I need to identify a couple of sets of rings:311 198 169A and 311 198 263A does this ring any bells for anyone??
Second question relates to the brake master cylinder-am i right in assuming there should be 2 brake light switches?and that theyre just connected in paralell?-i've only got one,and a dodgy looking bolt that looks like previous owners bodge!
cheers,peter
Piston rings/bake question
I'm never far from a parts book Peter...
169A = 85.5mm set (1600), standard size from engine # T0411 116 (early 67 by the looks of it)
263A = 83mm set (1500), with coil spring scraper rings From Eng # 255 340 to 1 100 000 (8/63 - 7/65)
It depends on the year of the car.
Single circuits obviouslly have had one switch and so would 68 and 69 twin circuit cars.
1970 and later cars have a switch for each circuit.
Replacement cylinders would I guess be universal, so would have 2 ports.
Hope that helps,
Mike.
Hope that helps,
Mike.
