squareback barn find out at last
Post your Type 3 Photo URLs here
nooky72
Post by nooky72 » 13th May 2009 - 9:42pm
cool!
scrunk
Post by scrunk » 13th May 2009 - 10:24pm
Nice find, looks like shes not seen the light of day for a good while.
How is she? Pretty good :D
Or fairly bad :(
'68 Fasty
'83 Camper. (aircooled)
'92 Polo GT coupe
'93 VR6 Corrado
nooky72
barn fined
Post by nooky72 » 13th May 2009 - 10:29pm
not bad needs a good looking at but all good inside floors ext the wings have gone at the bottoms so will be looking for some ...
Angelo Amato
square
Post by Angelo Amato » 13th May 2009 - 11:59pm
nice one !
front seats look amazingly mint !!
paulbugman
Post by paulbugman » 14th May 2009 - 6:02am
very cool what colour do they call that as a unusual colour
Post by Editor » 14th May 2009 - 12:48pm
The interior looks like Delta green, but the outside looks more turquoise. Two-tone colours from the factory have never been very common, so I suspect it may have been resprayed externally.
nooky72
SQ back
Post by nooky72 » 14th May 2009 - 8:10pm
well had the rear os wing off to day and not good lets hope the ns is better
Post by Editor » 15th May 2009 - 1:44am
It's all hidden behind the outer wing, so repairs don't have to be perfect, which makes it easier / not as expensive if you're paying for someone to do them.
It's pretty common to find rust there - often into the inside where seam sealer has cracked off.
nooky72
thanks
Post by nooky72 » 15th May 2009 - 6:05pm
thanks for the info ill get some pics @ week end ...
nooky72
bad bits !!!
Post by nooky72 » 16th May 2009 - 8:40pm
can i fix it ?
Post by Editor » 17th May 2009 - 1:33am
That depends on your talents.
There's not much that's all that structural in that area. The engine mounting area would have to be sound for 12" around. The body is fixed to the subframe much higher up at engine deck level so should be OK. The floorpan edge to body joint needs sorting at least.
In a way, it's as easy or easier to replace a decent piece of metal than weld up lots of holes.
You do have a fair bit of fabrication to do though. If you can't MIG-weld and panel-beat at the moment, you are going to have to learn! It's all hidden, so as long as it's solid, it should be OK.
paulbugman
Post by paulbugman » 17th May 2009 - 10:00am
yep as editor says you need to make metal panels , i used to use cardboard to make templates and go from there
Post by Editor » 17th May 2009 - 12:26pm
Sometimes thick clear polythene and marker pen is quite handy - you can mark the shape and any bolt holes etc before cutting out the rusty panel.
streetwagens
Post by streetwagens » 18th May 2009 - 2:13pm
Love it, not many UK cars left to be found. This can be fixed. Even some of the fresh imports have rotten bases to the heater channels, so need the body off anyway. Get yourself to a welding evening class and buy a mig, it will be the best money you spend. Head to www.welders.co.uk - excellent prices and service. Save it!! 8)
www.barnwest.com - where all the best rust goes!
