Type 3 Fastback Heater Channel Question
Type1234
Post by Type1234 » 5th July 2021 - 10:09pm
Does anyone have a picture or drawing of the heater flap hinge and a heater deflector assy which fits into the slot on top of a late Fastback?
Don
Type1234
Re: Type 3 Fastback Heater Channel Question
Post by Type1234 » 5th July 2021 - 10:11pm
That should read "that fits into the lot on the top of the heater channel"
Type1234
Post by Type1234 » 6th July 2021 - 11:43am
Post by broady_6 » 7th July 2021 - 10:18pm
viewtopic.php?f=4&t=3094&start=300#p62015
If you scroll down from there, there are some photos of the flap.
Type1234
Post by Type1234 » 8th July 2021 - 1:45pm
That is really helpful. Is the flap for the side with the notch for the wiring loom the same as the other side? It also helps knowing other people have faced all the same problems I am having and came out the other side.
Post by broady_6 » 10th July 2021 - 10:54am
Not exactly sure what you mean, there is no notch in the flap. There is a step in the sill on the passenger side for the wiring loom. Then a cover plate installed over the loom so the outter profile is the same as teh drivers side which doesnt have a step.
